The Millennium Tortoise (Captain's log)
Re: The Millennium Tortoise (Captain's log)
Great to see an XM estate doing what it was designed for - excellent!
- edmundator
After a few more loads today, this afternoon we went for an ice cream in glamourous surroundings.
Then we went to the tip.
2.0 Si auto estate
That's a very artistic photo
I like..
I like..
- edmundator
Thanks. I try, sometimes.
2.0 Si auto estate
- edmundator
After having lied to me about being too hot a few days ago, today the Tortoise got a bit hot an bothered and wet itself at the side of the road.
It is now at the garage and I am awaiting the bad news.
2.0 Si auto estate
Oh no! Hope it is a quick fix.
Definitely, I always "let on" to other classic Citroen drivers....sadly though I just don't see many around here thoughedmundator wrote:While I was out and about, I got a flash of the lights from someone driving a face lifted original C5 estate - I presume it was recognition of the XM rather than something amiss. Always nice to have a bit of camaraderie.
Fingers crossed your "incident" will be a cheap one
- edmundator
Had a report back from the garage. No significant fault with the cooling system, they only had to add max 1 litre to get up to full again and no signs of any leaks. Hasn't overheated and cooling fan appears to to be working appropriately. They noticed the coolant level light flash on briefly on a test drive (which I've noticed before and assumed it is an electrical fault somewhere) - they suggested replacing the coolant level sensor to ensure that's not at fault.
They say radiator looks original, so if there are further problems, it might be worth replacing this and the thermostat in the absence of any other obvious fault.
Having talked to me, however, they are going to investigate the aircon system to see whether this is working properly and whether the extra heat from this could be causing overheating whilst pottering around town/sitting in traffic.
2.0 Si auto estate
Well that's good news. I must admit I turn the Ac off when town driving.
