Post
by russ92xmsed » Fri Jun 28, 2013 8:43 pm
Damn auto correct spelling! I meant got rid of them!
Well done.
No I have missed this. I will reread!
Post
by citroenxm » Fri Jun 28, 2013 8:52 pm
russ92xmsed wrote:Damn auto correct spelling! I meant got rid of them!
Well done.
You have seen it.. i thought you had. You even comented on the excellent result with the rear panels lol..
Post
by russ92xmsed » Fri Jun 28, 2013 8:54 pm
I know ...I have just had a re read. You didn't mention you had replaced that panel for the mandarin one. That's why I was slightly confused there!! But yeah, good job. I left a response on your blog.
Post
by citroenxm » Fri Jun 28, 2013 8:55 pm
Got it.. hmmm im sure i talked of spraying a removed one..
Anyway.. never mind.. re test on monday.
Post
by russ92xmsed » Fri Jun 28, 2013 9:26 pm
Best of luck!
Jan-hendrik
Post
by Jan-hendrik » Fri Jun 28, 2013 10:36 pm
The brake light failure is of course the switch on the brake pedal. I can probably make a temporary repair,but it really needs replacing, as it has melted the plastic tab that presses on the contacts. Do all manual XMs have 3 wire brake switches, or only those with cruise control?
Yes, the plastic tabs melt, especially quickly on the AT models. I've glued in aluminum tabs on both XMs I've owned. I've read some Dutch owners have fitted relays.
AFAIK the brake switch on all models has 3 contacts with 3 lead wires for the CC models and 2 wires for a non cruise equipped model.
Post
by xantia_v6 » Sat Jun 29, 2013 5:03 pm
I have fixed the brake light switch by fitting a small wood screw through the switch cover with the head on the inside. The surplus point was trimmed with a Dremel. Brake lights now working, as is the cruise control.
I put the Lexia on it and no serious faults found, but no communication with the airbag ecu.
xantia_v6 on Sat Jul 06, 2013 6:30 am, edited 1 time in total.
Post
by xantia_v6 » Sat Jul 06, 2013 6:29 am
On Tuesday I managed to ge the immatriculation (registration) done. It was a bit tricky as the certificate de cession was signed by a daughter who had power of attorney over the ill vendor, and the woman at the sous- prefecture noticed that the signature did not match the one on the carte-gris. Fortunately I was able to get a letter of procuration from the vendors daughter, and that was accepted after a bit of discussion.
On Tuesday afternoon we drove up to Paris and had 3 days at EuroDisney with my niece and sister-in-law. It is a 3 hour drive from here, undertaken at a steady 135 km/h.
The XM ran faultlessly, and in each direction achieved 9.8 l/100km (29 MPG) on the trip computer, which is exactly the same as my Xantia V6s have achieved at the same speed.
On the way back we passed a diesel XM towing a very large caravan.
Post
by CitroJim » Sat Jul 06, 2013 9:31 am
Mike, that's excellent
Really pleased to hear all is good and the legalities are now nearly sorted...
What about its CT?
Post
by xantia_v6 » Mon Jul 08, 2013 6:01 pm
New Number plates attached...
In the street where we live in France.
At the Chateau de Pommard.
Flavigny-sur Ozerain (OK, not the XM, but a photogenic campervan)
