S1 24V back on the road
marc61
Re: S1 24V back on the road
Post by marc61 » Tue May 08, 2012 12:21 pm
Just phoned Citroen UK and they gave me FV600001991 for the engine number. She didn't inspire much confidence, computer says...!
Here's hoping for a simple H Reg No from DVLA.
Marc
About 8 XMs, now all deceased
Post by MTXM » Tue May 08, 2012 12:34 pm
That seems a bit of a coincidence Marc if the year of the car is also 1991! The number suggested by John sounds more likely. Just out of interest what is the car RP number (on front left hand side door pillar) that will determine the day the car left the factory. The VIN number suggests that your car is later than mine and my RP is 5072. With regards, Matthew T.
Post by xmexclusive » Tue May 08, 2012 1:48 pm
Apply with the number given from Citroen.
Make a written record of that conversation and keep it with the copy of the application and the V5 when it comes.
If at a later date an actual check proves a different number then just apply to get the V5 amended as an engine change.
Post by Dieselman » Tue May 08, 2012 5:04 pm
xmexclusive wrote: From Matthews numbers I think there is a fair chance your engine number will turn out to be 0004421.
How did you work that out?
Post by MTXM » Tue May 08, 2012 6:13 pm
I wondered that myself Will but did not dare to ask assuming I had missed something!! With regards, Matthew T.
Post by Dieselman » Tue May 08, 2012 6:49 pm
MTXM wrote:That seems a bit of a coincidence Marc if the year of the car is also 1991! The number suggested by John sounds more likely. Just out of interest what is the car RP number (on front left hand side door pillar) that will determine the day the car left the factory. The VIN number suggests that your car is later than mine and my RP is 5072. With regards, Matthew T.
Marcs RP number is 5177 which gives 11 January 1991.
Post by xmexclusive » Tue May 08, 2012 7:24 pm
My logic came from finding out that all 1991 V6-24v cars were numbered in the same VIN sequence.
I had previously assumed that RHD cars would have had a separate VIN block.
Took the difference between the VIN's and added it to the known engine number.
Hence the need to prove the logic with a third set of data.
Post by Dieselman » Tue May 08, 2012 7:26 pm
marc61 wrote:Just phoned Citroen UK and they gave me FV600001991 for the engine number. She didn't inspire much confidence, computer says...!
This is possible, it's beginning to make sense.
John said the engine number is in the order of
xmexclusive wrote: F V010000001
Note there are nine digits after the FV.
Matthews is
MTXM wrote: After checking my 1991 24v log book the engine number is 003447 (Vin ends 1238) if that is any use!
I have log books for three cars and note that the early car engine number has no prefix, so suspect Matthews is similar.
In build date order mine are
000660
DA49060042
DA43000154
I suspect he newer car had an older style engine as it has no EGR fitted, hence the lower engine type number. (DA43)
I suspect the prefix for the v6 is FV starting at 1 and running upwards, so a newer engine can have an apparently lower number.
Post by robert_e_smart » Tue May 08, 2012 8:04 pm
Hopping in at a very late stage; well done on the MOT pass Marc.
David Hallworth
Post by David Hallworth » Mon May 21, 2012 1:23 pm
I know I'm hellish late with this...
Great news on the MOT pass! It's always a big sigh of relief to get that good news.
If it helps to prove the theory, here's the details of the 3 24v's I've got:
Chassis No: AL0859, Engine No: 002832 (1991, J Reg)
Chassis No: AL1063, Engine No: 003388 (1991, J Reg)
Chassis No: AL0805, Engine No: 002809 (1992, K Reg)
Interesting to note the 1992 K plate has a lower engine number then the two 1991 J plates... I can't however prove it's never been changed either I guess.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
