2.0 8V bottom end rebuild (by idiots)
eyesoreracing
Re: 2.0 8V bottom end rebuild (by idiots)
Post by eyesoreracing »
I'm having pretty good luck finding the parts we need for this engine on Trodo.com, but there are a couple things they don't have.
Obvious one is rod bearings (!)
Less obvious one is the little seals along the side of the #1 and #5 main bearing caps. Any idea where to find these seals. Preferably somewhere that ships to the US.
eyesoreracing wrote: Tue Feb 11, 2025 12:51 am The car actually belongs to @bump_drft, and I am the assistance. Poor bastard couldn't afford better help...
I meant is bump_drft assisting. Getting ones fingers and nails dirty gives impetus to look after things better in future... ;)
Those gearboxes suffer weak synchromesh and with high mileage/lack of oil, will suffer bearing wear, but not normally.
A single click per revolution has to be something worn, or chipped. Probably worth splitting the box and having a look.
In case you don't have the gearbox manual. viewtopic.php?f=9&t=10855
You're doing a good job so far, will soon be back up and running, pretty cheaply too.
You're not the only person to have rebuilt a 2.0i fairly recently and it's the most common Xm engine, so I would think parts should be available.
P/nos. are:
95650951 original number
0606 J5 repair number.
https://www.catcar.info/citroen/?lang=e ... I9PQ%3D%3D
Found some 0606J5 https://www.lyonparts.com.br/c/motor/br ... ra-xantia/
I would think an engine builder/machine workshop would be able to supply suitable bearing shells. If all else fails have yours re-metaled.
Also found some on Autodoc. https://www.autodoc.co.uk/kolbenschmidt/8167751
KOLBENSCHMIDT are pretty big on engine parts, so worth checking their catalogue.
There are others on Autodoc. https://www.autodoc.co.uk/car-parts/mai ... /31145-2-0
The bearing seals are P/no 0127 40, which should be readily available.
eyesoreracing
Thank you for that bearing seal part number, I wasn't having any luck finding that before!
These parts are easy to find on Autodoc, but they only ship to Europe. Also found them on Cirtoenpartsdirect.co.uk, but they only ship within the UK. So we'll probably have Autodoc ship to my friend in Germany and have him ship the bearings to California.
Try Spareto, they send Worldwide.
You should find everything you need here https://www.kmotorshop.com/en/article-l ... 50&style=1
eyesoreracing wrote: Tue Feb 11, 2025 1:07 am I'm having pretty good luck finding the parts we need for this engine on Trodo.com, but there are a couple things they don't have.
I believe King bearings list them, they are US based.https://www.kingbearings.com/
Southerneruk
Post by Southerneruk »
You have the R in the wrong place in your link, you put "Cirtoenpartsdirect.co.uk" instead of "Citroenpartsdirect.co.uk"
bump_drft
Post by bump_drft »
My wife and cat enjoyed (detested) this lovely piece of art in my front hallway for a bit, but it has since been placed back on top of the engine, and haphazardly dropped back into the car. What's left is mostly making sense of this rat's nest of wiring (someone clipped some wires and skipped the connectors it looks like).
1990 2.0i 5-speed
Located in New Orleans, USA
bump_drft
Post by bump_drft »
Can anyone share where this shift linkage bracket connects to? We're stumped
1990 2.0i 5-speed
I'm surprised it doesn't fall naturally to it's position, as that is the reaction link for the linkage swivel.
It bolts to the back of the gearbox, below the selector. Spin the link rod round 180 degrees.
Image from above.
Exploded diagram
