Re: Pauls 1991 V6 24v Manual ...
2.1 td bolts are a pita.. One is simple the other is virtually impossible... The 24v one is more central and over a bit thereforexa bit easyer to get too..
Yea you will.. Ill take off the inlet air pipes... Lol.. Proper induction noise!!
Post by MTXM »
It was good to hear you have the exhaust cracked Paul but what is that bandage around the mouth of the rear bank pipe! Regards, Matthew T.
^ Heat proof tape. Presumably to stop heat transfer into local components.
paul.
Regarding splitting taper fit joints, often a plitter isn't required, just some sharp clouts sideways on the joint and it will part.
MTXM wrote:It was good to hear you have the exhaust cracked Paul but what is that bandage around the mouth of the rear bank pipe! Regards, Matthew T.
I can only assume its heat protection as will says..
Always been and being stainless manifolds always will be..
Post by MTXM »
That is interesting Paul as my 24v manifolds do not have this feature but are indeed stainless steel as you state. Regards, Matthew T. PS. There is a metal jacket type heat-shield around the pipework not shown in this photo.
Post by MTXM »
The original metal heat shield should extend to the manifold pipework outlet Paul so your must be partly or completely missing I guess! Regards, Matthew T.
citroenxm wrote:2.1 td bolts are a pita.. One is simple the other is virtually impossible... The 24v one is more central and over a bit thereforexa bit easyer to get too..
:lol:
Apparently Citroen only fitted the manifolds as stainless from factory but Peugeot in the 605 fitted a full stainless system to their 24v 605s ....
But Citroen got the better styling and suspension! :)
It's strange how two cars that are quite similar end up with different parts. But they weren't built in the same factory, so maybe it was a supply thing.
Same floor pressings which peugeot continued with into 607 production and into 2000.. Right up to 2005 or so.. And same fromt subframe on 607s too....
