Re: Russ's 2.1 SED Auto
Post by citroenxm » Tue Feb 19, 2013 4:14 pm
If there is only one break in the hose you can do a tempery repair by splitting it and putting in a piece of pipe the same size as 3.5mm hydraulic pipe... ;)
Post by russ92xmsed » Tue Feb 19, 2013 4:29 pm
Yeah this is what Ken has suggested. Think I'll do a full replacement. :D I haven't got 3.5 mm pipes lying around unfortunately.
Could I be an absolute pain and ask you how to do it. Any need to de pressurise the system and what clips to use ect? Would be great. :oops:
kenhall
Post by kenhall » Tue Feb 19, 2013 6:15 pm
No need to de-pressurise. If the replacement you are buying is a pukka Citroen one then it should come with a new clip. Trouble is ideally you need a fancy pair of pincers ('Clic' type??) to get the clip fastened - alternative is to use a good quality tie wrap instead.
Ken
Post by russ92xmsed » Tue Feb 19, 2013 6:22 pm
It is a genuine Cit part I believe. We'll see if does turn up with a clip.....
Thanks for the tip Ken. Reading up on it, sounds quite straight forward to replace. Time will tell.
Post by CitroJim » Wed Feb 20, 2013 4:24 pm
It's not a bad jib at all to replace Russ. By far the worst job is the clean-up...
Go to a good factors and buy a gallon of loose (i.e. not in a aerosol) brake cleaner and use that liberally to clean up. Paint it on and blast it off with an airline. It'll do a lovely job...
Post by russ92xmsed » Wed Feb 20, 2013 4:55 pm
Cheers Jim, I was looking at those photos and wondering how long it take to clear it all up. Gone everywhere!
Post by CitroJim » Wed Feb 20, 2013 5:08 pm
One good thing about LHM is that once the leaks are stemmed traces of it soon fade, even on driveways, but when it soaks road muck it can hang around a bit...
Despite looking a mess it’ll do no general harm but can attack some rubber so it's good to keep it off of gaiters and engine mounts...
Post by russ92xmsed » Wed Feb 20, 2013 5:18 pm
Jolly good. It did leave a decent sized stain in the road....hehe! :twisted:
I'll give it a good clean and make sure it's all off the rubber bits.
Post by captainhaddock » Fri Feb 22, 2013 7:25 pm
hey, Russ...had that the first day after I bought my 2 liter, giving her a few gynmnastics.
NOthing to worry about, in fact I made a temporary repair and forgot about it's...still leak free! :) Good to know Xantia bits fit as well, wonder why they never caused any hassle with me. Will give them a second chance :) (from my old Xant)
Post by russ92xmsed » Fri Feb 22, 2013 7:46 pm
Hi Jaap, good hols?
Bit annoying it has gone, but new pipe arrived today and just got to fit it now. However, I do not relish doing it this weekend with this bitter weather. It's soooo cold out there. :( :lol: .....just not hard enough!!!
I thought they were obsolete for XM's ...so was delighted Xantia ones fit and one happened to be on the 'bay too. Genuine Citroen part too.
Got a great pic of the Charleston I did for Frank. Looks good. I believe he sent it to you too.
