evening Geoff
Is the A/C condenser still available, not riddled with holes and can it be posted to me if all the above checks out.
Thanks
Battlescar - now scrapping 2.1 TD Mk 2 Auto
Re: Battlescar - now scrapping 2.1 TD Mk 2 Auto
I have that Dean...
Geoff Lebowski
[quote="Geoff Lebowski"]Hi Steve,
Pretty sure I have front door speaker grills...
the front left door window rubber/seal that brushes against the window as it raises and lowers - exterior weather strip?.. not sure what you mean. To clarify I'll post an image off Citroen - service
Rear ash tray I have
blanking panel for centre console - do you mean the rear panel above the rear ash tray that holds switches and/or blanks?
cheers[/qoute]
Which part from here?
cheers[/qoute]
1996 XM 2.1 TD Auto Hatchback
- steelcityuk
Hi Geoff,
It looks like part number 9 please.
It's the blanks I'm after if possible.
Thanks.
Steve.
Thanks.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
- Kit
Hi Geoff, Is the aerial available? Cheers, Kit
'95 2.1td manual VSX Estate Silver rp6791
'95 2.1td manual VSX Estate Green rp6769 sorn
Geoff Lebowski
Steel City - what do you mean by blanks? Part number 9 is no problem.
Kit, the car never had one I'm afraid
Just Pm'd you, then saw this you gitcitroenxm wrote:I have that Dean...![]()
Hi Dean
Could be worth trying nearer home.
jamieb
Hi Geoff
I'm after two front door locks, with keys if poss. I don't mind ignition and doors using different keys...
Jamieb
Jamieb
Geoff Lebowski
Hi Jamie,
They are already spoken for.....sorry
