L592 EVN formerly J2 CXM
Re: My new project
Post by Dieselman » Tue Aug 09, 2022 6:49 am
Julianw wrote:
Mon Aug 08, 2022 10:38 pm
iirc an owner (dollywobbler?) on another forum got near to 1000 miles from a tank on a 2.1td XM...
1000 miles would equate to 57 mpg, so could be achieved, with care.
It makes sense for what was "The most comfortable car in the World" to have a long range between stops.
maxferreira
Orga / RP numbers: RP6043
Re: My new project
Post by maxferreira » Tue Aug 09, 2022 10:42 pm
i'm telling you, i bet i can do 1,000 miles per tank
so much so i'm going to try it!
watch me embarrasingly run out of fuel lol!
maxferreira
Re: My new project
Post by maxferreira » Tue Aug 09, 2022 10:44 pm
not much to report really, it's going great!
recently repainted the rear bumper chrome strip, it's far from perfect but looks a lot more presentable!
maxferreira
Re: My new project
Post by maxferreira » Tue Aug 09, 2022 10:46 pm
oh, and did i mention this is now my only car?
well as of tomorrow it will be, unfortunately i've made the decision to scrap my C5, due to the automatic transmission just about failing, and a few more issues.....i'm going to buy another C5 in the coming week or so but for now, i only have the XM
Re: My new project
Post by Dieselman » Thu Aug 11, 2022 6:48 am
We do like a game of fuel light roulette.
Red...or Black...?
Re: My new project
Post by citroenxm » Thu Aug 11, 2022 8:08 am
Well to add to this. .one two recent trips to CCC rallies in our 2.1td auto exec S2 i also got around 53mpg one trip was fully loaded with me, wife and child plus luggage. I found it disbelief too...
I have found though that using the car with the load or kickdown cable removed and using the gearbox set speed changes helps.. it not holding gears unnecessary and revving away for no reason.. it changes up and the torque is so good just pulls on. The nature of the high revving box is completely pointless on the 2.1 ..
maxferreira
Re: My new project
Post by maxferreira » Sun Aug 14, 2022 12:23 pm
Time to sort something that's been slightly bugging me
i have slight doubts as to how well my hydractive system works
it does work, per say, evident when replacing spheres.....centre sphere was released with a clunk upon closing doors etc
anyway, the ride can be slightly firm at times, sport mode light barely illuminates upon actioning the switch (it does with ignition though)
upon opening the door, i get a clunk and a very slight lean to one side so i believe in a way it does work
i've been told i should hear a buzzing noise from the ECU when a door is open, this does not happen, only a clunk
so i suspect it needs a diode repair? reccomended diodes for this? i'll likely wire them in externally
maxferreira
Re: My new project
Post by maxferreira » Sun Aug 14, 2022 12:25 pm
otherwise the car is doing well
indicator stalk is suffering in the heat, become quite sticky and had an incident of smoke from the steering column and relay chattering
i have a replacement en route from the ever helpful paul, as well as a few other little bits
for now, my solution is to be a little more forceful with cancelling a signal than i would be normally, this ensures it will remain in the centre position when not in use
i also need to investigate some electrical issues under the bonnet too, mainly the power supply to the fuel solenoid
Re: My new project
Post by citroenxm » Sun Aug 14, 2022 12:39 pm
The buzzing doesn't.come from the ecu.. it comes from the electro valves under the car..
maxferreira
Re: My new project
Post by maxferreira » Sun Aug 14, 2022 1:10 pm
even more news
so the ring terminal supplying the fuel solenoid has the cable snapped off on the ring connector
bonus news is, there's power there!
so i can do a permanent fix and remove my bodge from the glow plug relay (it's served me well for the last 3k)
pin 3 from the plug relay can be used as a temp supply to the fuel solenoid
