Tony's 1994 Xm prestige. 2.0 turbo.
djg
Orga / RP numbers: 7903
Re: Tony's 1994 Xm prestige. 2.0 turbo.
Post by djg » Sun Aug 10, 2014 11:43 pm
Actually, mine does the same but I never really bothered to find out why. All other functions are present and correct, nice display of fuel consumption and all but no distance on remaining fuel.
Bye,
Gábor
Bertie-Bassett
Location: May I just say? That's a smashing blouse you have on.
Post by Bertie-Bassett » Mon Aug 11, 2014 7:26 am
Strange as mine had always worked up till now though.
citroen xm 1994.
djg
Post by djg » Mon Aug 11, 2014 2:33 pm
I always wondered how on earth it can guess how much fuel is left in the tank (it can't, actually, it has to start with the assumption of a full tank and go on from there).
Bye,
Gábor
Post by Dieselman » Mon Aug 11, 2014 6:48 pm
It uses the fuel level sender as the sensor. It might be worth having a look at it.
djg
Post by djg » Mon Aug 11, 2014 10:20 pm
There is no direct connection to it. It might get some data back from the instrument cluster control unit, the circuit diagram doesn't reveal that. But my fuel level meter works all right. This still leaves three wires between the instrument panel and the display that might, theoretically, be responsible (with a contact problem) but they aren't marked on the diagram as to what signal they carry.
What makes me wonder besides this is that the board computer diagram doesn't mention the fuel level sender, neither on the circuit or the harness diagram. They normally show all related parts even if the connection isn't that direct.
Bye,
Gábor
Bertie-Bassett
Post by Bertie-Bassett » Sat Aug 16, 2014 9:15 pm
It's working again. Also I've notice my gear selector getting stiff between changes. Any ideas ??
citroen xm 1994.
Bertie-Bassett
Post by Bertie-Bassett » Sat Aug 16, 2014 9:18 pm
It's an automatic gearbox.
citroen xm 1994.
Bertie-Bassett
Post by Bertie-Bassett » Wed Oct 29, 2014 4:30 pm
My Xm outside sister house today. Decided not display tax anymore.
citroen xm 1994.
Bertie-Bassett
citroen xm 1994.
Bertie-Bassett
Post by Bertie-Bassett » Wed Oct 29, 2014 4:33 pm
Abit brighter this one.
citroen xm 1994.
