sageman's 'barn find' v6 sei s1
Re: sageman's 'barn find' v6 sei s1
Post by White Exec » Fri Oct 12, 2018 12:34 pm
One EV, then, so just one tell-tale LED will do.
sageman
Post by sageman » Fri Oct 12, 2018 1:18 pm
Ok now I understand these drawings better I’ve looked at my service manual which has the 7n connector drawn in the correct place
If I understand it correctly
1- brake pressure switch
2- body control sensor
3- body control sensor directly from positive skipping ecu
4- body control sensor
5- body control/brake pressure sw ground
6- EV positive
7- EV negative/back to ecu
Will upload pictures later
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
sageman
Post by sageman » Fri Oct 12, 2018 1:57 pm
After looking through about 20 differant wireing diagrams in my two s1 books the only difference I can see is 7 either goes back to ECU or to ground
1976 Reliant kitten
Post by White Exec » Fri Oct 12, 2018 4:47 pm
Almost right.
1- brake pressure switch OK
2- body control sensor its 5-way brown connector pin 1
3- body control sensor directly from positive skipping ecu its 5-way brown connector pin 3
4- body control sensor its 5-way brown connector pin 2
5- body control/brake pressure sw ground its 5-way brown connector pin 5 and Gnd
6- EV positive its 2-way brown connector pin
7- EV negative/back to ecu NO - EV negative, down to Gnd
Important that the EV receives correct polarity, as it contains an internal diode (which can be damaged if polarity wrong).
Susp ECU outputs +ve to EV.
The brown male connector on later EVs was actually marked + and -, moulded into the plastic.
sageman
Post by sageman » Fri Oct 12, 2018 5:02 pm
Sorry you’ve confused me talking about a brown plug is this what plugs into the body control sensor
1976 Reliant kitten
Post by White Exec » Fri Oct 12, 2018 7:09 pm
Citroen connector connections are usually labelled something like this:
7N2 - 7way, Noir (black), pin2
15B6 - 15way, Blanche (white), pin6
2M2 - 2way, Marron (brown), pin2
The plug/socket at the sensor is shown as brown.
Colours of connectors are stated in the service sheets/circuit diags to make them easier to locate on the car.
sageman
Post by sageman » Fri Oct 12, 2018 9:47 pm
as promiced some photos
oh of corse the letters would be for colours but in french duhhh i was was wondering what those letters meant thought they might just have been random
1976 Reliant kitten
Post by White Exec » Fri Oct 12, 2018 10:29 pm
So, you had those S1 circuit diagrams all along?
Those show a quite different set of connections for the EV etc.
Amazing how useful the right diagram is!
sageman
Post by sageman » Sat Oct 13, 2018 3:14 pm
Honestly I have no idea which one mine is there’s about 20 differant diagrams for each ‘thing’
I never looked as these books are so overwhelming I had no idea what I was suppose to be looking for
1976 Reliant kitten
Post by White Exec » Sat Oct 13, 2018 4:06 pm
If you have a fairly complete/large set of Citroen diagrams, for each Section - you're in 58 at the moment, and 581-00/21 - there will be an Contents page at the front of that Section, which lists the circuits, divided up into Gauche (=LHD) and Droite (=RHD). Note that -00 pages apply to both LHD and RHD. It then lists the diagrams by RP number. This will take you to the correct diagram.
So, go for the right Section (58 is Suspension - in this case, there's a susp icon at the top of each circuit page, which helps)
Go for RHD
Go for your RP number (which is 5876)
This will take you to a Circuit/Page, eg 581-00/21
You'll notice that there are a series progressing pages, eg (I'm making these up)
581-00/20
581-00/20a
581-00/20b
These show how the succession of circuit designs as they changed over time. There can be lots of these changes, which is why it's important to get the RP (production date) right when using the manuals. That's why we go slightly bananas when the number is not properly displayed in a member's Profile or Signature.
If you have a large set/collection of those original Citroen diagrams, and maybe other Workshop pages too, they are extremely valuable for the info they contain, and should be cherished in themselves! :) We might be asking you to let us know which pages you have, as several of us have gaps in our own material!
