K-BAN has a new home
Re: K-BAN has a new home
Post by Dean » Tue Feb 02, 2016 9:46 pm
Aaaaagggghhhh! I can't believe you mentioned the L word while the poor guy is rebuilding his sunroof, sorry Ray, the whole jobs doomed!!. Don't forget to blame Russ!
raynoon
Orga / RP numbers: 6043
Post by raynoon » Wed Feb 03, 2016 7:54 pm
Bloody sunroof!
Fitted the cassette, and then conducted a water test... Everything was going great... Then the drivers side started dripping water.
It seems the water is 'over powering' and by-passing the drain, it's flowing straight over the edge of the cassette and not dropping into the channel. Took the cassette out, placed it on the floor and conducted the water test again. It worked perfectly. Not a drop over flowed. Then looked inside the car and it seems the wiring loom is causing the problem. I can't remember where the wiring loom is supposed to sit, in conjunction with the cassette.
Hope you're still following?
I'm at a loss as to what to do next. Do I silicon the whole edge of the cassette? Do I drill holes to allow the water to drop into the tray quicker? I tried drilling a hole but the frame is made of aluminium.
I think I'll drill a few holes, seal the edge of the cassette with silicon, and try and seat the wiring loom correctly.
jamescarruthers
Post by jamescarruthers » Wed Feb 03, 2016 8:08 pm
May I recommend Silkoflex 291 marine adhesive or something similar from their range? We use it on boats and wouldn't touch RTV sealants with a barge pole for longevity.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Post by Dieselman » Wed Feb 03, 2016 8:08 pm
The wiring loom gores just outside the cassette, between the roof skin and sunroof support brackets.
Why am I not surprised it's still leaking.
raynoon
Post by raynoon » Wed Feb 03, 2016 8:14 pm
Dieselman wrote:The wiring loom gores just outside the cassette, between the roof skin and sunroof support brackets.
So at no point does the loom get 'trapped' between the cassette and the roof? It seems this has been a problem for a while as the metal has become rusty.
Post by Dean » Wed Feb 03, 2016 8:22 pm
My sunroof always leeked on the passenger side, when I looked years ago they had trapped the loom between the sunroof cassette and roof, water wicked out along the loom and dripped out above the passenger window, I dropped the cassette pulled the loom out and its been fine ever since.
Don't drill holes in it, ifitsput back in correctly it will not leak.
Russ! Hang your head in shame!!!!! ;)
Post by Dieselman » Wed Feb 03, 2016 8:24 pm
The nature of how the roof cassette collects water makes the roof rust at the edges of the reinforcement plate.
The whole idea is a disaster.
You did well getting the cassette back in on your own, how did you manage it?
raynoon
Post by raynoon » Wed Feb 03, 2016 8:30 pm
I had a helper!
raynoon
Post by raynoon » Wed Feb 03, 2016 8:38 pm
jamescarruthers wrote:May I recommend Silkoflex 291 marine adhesive or something similar from their range? We use it on boats and wouldn't touch RTV sealants with a barge pole for longevity.
It only needs to hold a dribble... It's not quite titanic-like yet!
Post by russ92xmsed » Wed Feb 03, 2016 9:46 pm
:oops: sorweeeee.
