CEO 2.1turboSED auto
- raynoon
- Orga / RP numbers: 6043
Re: My XM "The Boss"
Today, whilst driving along without my (broken) radio I noticed a random/rapid clicking noise coming from the glovebox, along with some lights illuminating on the dash, coupled to this was the random starting of the cooling fans... Is this a failing relay? A Bitron?
jonathan_dyane
Yes that is related to the Bitron relay thing kicking in although I'm not sure what the most likely cause of the problem. I'd start by checking the connections to the sensors on what looks like a thermostat housing on the cylinder head (I'm sure pulling one of the connectors off will cause the problem you describe)followed by testing the sensors themselves followed by the relay itself.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
That orange light is a signal of "Engine Temp rapidly too high"...
Its controled by the Brown Sensor on the thermostat house, that isnt on a 2.1 .. just where the top rad hose goes to the engine...
Pull the plug off and check for corrosion. Its a dodgy connection Ray...
- raynoon
Thanks Jonathan and Paul, Paul would you like me to add this to the list?
- raynoon
I re-wired the sidelight, the wiring had corroded where it meets the connector and also where it joins the main wiring loom. Working perfectly now.
Excellent work.. I fitted a side light bulb to K ban today but the contacts in where the bulb sits were quite bad.. Gave them a quick rub to clean then a little..
- raynoon
Today CEO went off to have some work done.
I wonder where!!!
- raynoon
far far FAR away!
- raynoon
Did you volunteer for this Russ?russ92xmsed wrote:Yep, very different. Rays is much lighter.
I get so confused with all the greys Citroen used. We need to complete a colour chart with all the body colours listed, paint codes and dates they were used.
