1998 XM - 2.1td - Steamy Windows!
Re: 1998 XM - 2.1td - Steamy Windows!
Post by CitroJim » Sun Mar 03, 2013 2:39 pm
russ92xmsed wrote:My only gripe with wobbly webs are they are a little tricky to put back on the car.... Probably just me :roll: :lol:
No, I don't think so Russ, you have very little to sight through on a Wobbly Web...
Post by xmexclusive » Sun Mar 03, 2013 4:10 pm
Bit of wheel bolt sized threaded rod with a screwdriver slot in the end.
Hang the wheel on that.
Post by Dieselman » Sun Mar 03, 2013 6:11 pm
I wouldn't put Wobbly Webs on a Series2 car, they were never standard and will look wrong. The V6-24V wheels were the early Exclusive wheels, followed by Monte-carlo's.
Post by russ92xmsed » Sun Mar 03, 2013 6:14 pm
Yes I suppose the early 24V alloys would look more standard, but I think you can get away with wobbly webs on a mk2 like James's.
Post by citroenxm » Sun Mar 03, 2013 6:18 pm
If the wheels have a CENTRE hole in them, then remove the centre cap, then lining up is soooo easy then!!! Works first time every time...
Post by russ92xmsed » Sun Mar 03, 2013 6:21 pm
Good point!
Post by robert_e_smart » Sun Mar 03, 2013 9:21 pm
Dieselman wrote:I wouldn't put Wobbly Webs on a Series2 car, they were never standard and will look wrong.
They were available throughout. At the end they were centre-less. I had a 2000 XM with these on it.
turbo_imp
Post by turbo_imp » Sun Mar 03, 2013 9:45 pm
ok, so I know that you guys might call sacrilege on this one, but I did a nasty paint picture of a green XM on alfa wheels -
Center bore is wrong but that is easily fixed, I quite like them :)
Post by russ92xmsed » Sun Mar 03, 2013 9:58 pm
I think XM's are quite a challenge when it comes to matching alloy wheel styles, they seem to suit heavier designs, in my opinion.
They kind of work...I wonder if a centre cap with chevrons might work on them too. :D
Ah that's it now James, your going to get me thinking!
Post by Duke » Sun Mar 03, 2013 10:00 pm
Nice 'shopping!
If I'm right in my thinking, then those Alfa Wheels will be 5x98...
AKA the same as a CX...
Interested that you say that it's easily fixed - there's some 5x98 Alfa Wheels here on a CX that would good mightily good on the Prestige.
Are there special adapters or something as I believe XMs are 5 x 108...
