Post
by russ92xmsed » Mon Nov 11, 2013 11:27 am
CitroJim wrote:Thing is with the XM the age they are now you'll always find jobs to do on them...
So true.
Post
by captainhaddock » Mon Nov 11, 2013 12:15 pm
Richard2cv wrote:Good work on the subframe. A job I've been putting off for months on my car.
Did you just use underseal on the cleaned metal??
Thanks. No I treated with Kurust before and after for which I drilled 2 holes. Applied a lot of Kurust and use airgun to spread in between. After that I coated the metal and welds with zinc primer twice.
(@Jim in between I decided to clean my workshop 'kitchen' and even did some paint work there
Afterwards I applied underseal and next week will waxoil the inner works as well. Should hold out for a while.
Post
by CitroJim » Tue Nov 12, 2013 5:55 am
That’s not going to give any further trouble Jaap
Post
by Charles M » Fri Dec 06, 2013 10:17 am
[so smug someone will string me up mode] What's ABS? [/so smug someone will string me up mode]
Post
by russ92xmsed » Fri Dec 06, 2013 10:56 am
NNNNNNNNNOOOOOOOOOOO!!!!!
oh dear Jaap....what are you doing to them!
Post
by captainhaddock » Fri Dec 06, 2013 11:18 am
I let them work - that's all! I don't buy them to look at them!
Give me some moral support here!
Post
by russ92xmsed » Fri Dec 06, 2013 12:47 pm
It'll be alright Jaap. Honest. Don't worry, everything will be okay..... That enough moral support!
I don't know...looking at them is far less expensive...
Don't you have some spare sensors from the black scrapper? At least it is a Teves system, if they were both Bendix it could be a lot worse.
Post
by CitroJim » Fri Dec 06, 2013 5:28 pm
Jaap, here's another bootful of moral support...
Every Citroen I have ever owned has needed ABS sensors so I have heaps of empathy...
Post
by captainhaddock » Fri Dec 06, 2013 6:41 pm
Mine too jim
Liz just got home and the light did NOT come on. So not too bad there. Possibly a duff rear sensor
But they are easy to find.
Will have a go at the Turbo now, wish me luck, not in the right mood really...
