1998 2.1 VSX Auto new project
Re: 1998 2.1 VSX Auto new project
Post by Dieselman » Sun Jun 15, 2025 10:05 am
That alternator has definitely done some work.
When the car was designed and had a 7 piston pump, the single hydraulic pipe followed a route that allowed the alternator to be extracted. The 6+2 pipes cross over the alternator.
I'm really interested to see if the £13 kit is a workable task. how are the slip rings held on and connect to the armature?
Citjon
Orga / RP numbers: 8032
Post by Citjon » Sun Jun 15, 2025 9:23 pm
xantia_v6 wrote:
Sat Jun 14, 2025 7:04 pm
There is an "engine running relay" which takes its signal from the alternator and disables the A/C, heated seats and heated rear window, so probably related.
That's good to know, thank you.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
