Post by MTXM » Wed Jan 25, 2017 7:10 pm
Many thanks Will and hopefully I might now be able to enjoy driving the car! With regards, Matthew T.
Post by Dieselman » Wed Jan 25, 2017 7:13 pm
Time to sell the Gold manual one...
Post by russ92xmsed » Wed Jan 25, 2017 7:24 pm
Well done Matthew that's really good news.
Your heart must have sunk though hearing that clatter. Amazing job sorting it out like that. A huge relief!
Post by MTXM » Wed Jan 25, 2017 8:18 pm
Sorry Will my wife would not let me!
Many thanks Russ and you are spot on there!
With regards,
Matthew T.
raynoon
Orga / RP numbers: 6043
Post by raynoon » Thu Jan 26, 2017 9:04 am
Well Done Matthew, I'm looking forward to seeing this car at a show this year.
Post by MTXM » Thu Jan 26, 2017 9:24 am
Thank you Ray and I do hope to use the car later this year! With regards, Matthew T.
Post by MTXM » Sat Jan 28, 2017 7:34 pm
I moved the car out of the garage today and all seems well with vital fluids remaining in place etc. It was necessary to refit the section of exhaust under the engine as the joints I had loosened then started to blow but otherwise no further attention required. The hydraulics seem to have benefited for the rebuilt FDV although the steering still feels a little bit stiff. As the car came off the road prematurely I realize I still have nearly six months mot so she may get some use shortly! Regards, Matthew T. PS. I also sorted out the garage including my recently acquired spare 12v engine and set up the cobalt car for major surgery!
Post by Dieselman » Sat Jan 28, 2017 11:23 pm
A veritable breakers yard there, Matthew.
Post by MTXM » Sun Jan 29, 2017 9:20 am
Yes Will I aim to complete with the best of them! Seriously though I hope to run XM into my dotage and bits are drying up elsewhere. With regards, Matthew T.
Post by MTXM » Sun Jan 29, 2017 1:15 pm
Although the engine starts with ease and ticks over very nicely it does appear to be running a little rich and on revving up it is certainly quite 'flat'. I have checked the plugs which are a bit sooty, plus the air cleaner, idle valve hose, lambda sensor wiring etc. without any obvious faults. A diagnostic check indicated faults with the manifold temp senor and throttle potentiometer, which I have changed without improvement, although the faults codes have not reappeared. It may just be stale petrol or a bad connection somewhere, but does anyone have any other thoughts? With regards, Matthew T.
