Re: ANOTHER 24v ON THE ROAD!!!
Post by xmexclusive » Tue Sep 23, 2014 8:48 pm
On a deadlocked Mk2 the finger pull method does not work.
Guess how I know.
Ideal time to replace the rusty fixing bolts with stainless steel ones.
Post by citroenxm » Wed Sep 24, 2014 8:23 pm
Think it be better to lift these lock posts out of here and make a door lock thred..
that be good .. please.. ;) :)
djg
Orga / RP numbers: 7903
Post by djg » Wed Sep 24, 2014 8:26 pm
I actually had one but it didn't get much attention. I'll look up the link.
viewtopic.php?t=6154
Bye,
Gábor
Post by citroenxm » Sun Oct 05, 2014 5:09 pm
Had the 24v out this sunday for a little drive out.... but a niggle appearing..
The ABS light was having a field day.. it was on off on off on.. then stayed on, but every time I braked it went out!!
So I decided we needed to read the ECU with Lexia..
Firstly though, was the dire need AGAIN to tighten the HP Pump belt! They seem to stretch easilly. I can see why they switched to flat ribbed with spring tenioner for the Xantias!! Anyway, managed that after a short while, then got Lexia out..
One or two solinoid errors there, though all are intermittend, I wonder if its just a bad connection to the Block or something..
I also had a look at the Hydractive ECU... Though currently the steering wheel angle sensor is not fitted due to a temperary colum swap.. it was NOT in bad shape at all!
Its STILL a joy to just "Plod" along at 60 in her too!!!
Post by captainhaddock » Mon Oct 06, 2014 9:13 am
Sure you will fix that but having said that, rather you than me. I am so happy I see no orange lights at all and even the ABS worked last night when braking hard (and I mean really hard) for a sheep that was just curious to see if I would stop or not...and then for a torn off tree part on the road. Still think the XM has a long braking distance compared to smaller cars I was used to....
Post by russ92xmsed » Mon Oct 06, 2014 10:24 am
Weight Jaap. XM's are heavy cars... so more to stop. My theory anyway. I kind of know what you mean.
Post by citroenxm » Mon Oct 06, 2014 10:38 am
This morning after the lexia session and clearing the faults the drive into work gave me no abs light after the usual flicker test.. so see how long that lasts..
I beleve the faults are all linked the abs block electronic board thats mounted on it with a number of plugs..
see how she goes..
Post by xmexclusive » Mon Oct 06, 2014 11:53 am
Paul,
I think you are right to target those green board connectors once you see what the next read gives.
Post by MTXM » Mon Oct 06, 2014 6:47 pm
I believe the faults are all linked the abs block electronic board thats mounted on it with a number of plugs..
If you mean the black relay above the valve block I agree that may be the cause of your problems Paul as I had a persistent ABS fault with one of my cars which was cured after replacement! With regards, Matthew T.
Post by citroenxm » Mon Oct 06, 2014 7:01 pm
Today... to work and back, totaling 30 odd miles the ABS light STAYED out and I didnt get a peep out of it!!!
