1998 2.1 VSX Auto new project
Flegmaatikko
Orga / RP numbers: 5082
Re: 1998 2.1 VSX Auto new project
Post by Flegmaatikko » Mon Oct 28, 2024 4:11 pm
I also hear a clicking sound when this happens and to my ear it's the solenoid trying to pull. Someone a long time ago had a topic about this problem on the Finnish Citroen forum and even though he didn't find the problem he found that the solenoid gets power but not enough to engage the starter. Mine usually does this when the engine bay is hot and that's enough to make a bad connection.
Of course, it's not unusual for the starter to fail. How many miles has it done?
-90 XM V6 ERT
Post by Dieselman » Tue Oct 29, 2024 7:30 am
Use a jump wire from the solenoid Ign contact to Batt+ve to test the starter.
Mine was doing this and turning slowly, which a strip and clean fixed both issues. I suspect e brushes were sticking in their guides.
Citjon
Orga / RP numbers: 8032
Post by Citjon » Wed Oct 30, 2024 7:41 am
It has done 162k miles, the starter looks like it has been reconditioned already as it is painted black all over. I think a strip down and clean up is the way forward, depending on what I find..
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
Post by Dieselman » Wed Oct 30, 2024 8:03 am
I suspect it will be the later, smaller Mitsubishi starter motor, in which case it is very likely to have been reconditioned already. The early Valeo ones are incredibly robust.
Citjon
Post by Citjon » Mon Nov 04, 2024 8:54 am
Thanks Will, are they fully interchangeable? I think I've got a spare Valeo one somewhere - do you know the part numbers?
89 CX25DTR T2
72 D Super 5 Black
Post by Dieselman » Tue Nov 05, 2024 7:19 am
Not sure, they have a differing number of teeth on the pinion.
Citjon
Post by Citjon » Thu Jun 05, 2025 10:48 pm
Edit: disconnected the Textron alarm unit and the indicator is no longer stuck on.
Resurrecting the car after the winter lay up, I decided to strip down the starter motor. It looks like a Valeo unit, probably a D7R8 although the label has been removed or painted over so can't say for certain. Some Mitsubishi / Bosch ones look very similar. The brushes were OK and cleaned up well along with the commutator. The solenoid is a sealed unit so cleaned it where I could and refitted it.
Fitting it back on the car it has worked perfectly 9 times out of 10, so either the solenoid is dodgy or I need to do the relay mod. I will see how it goes over the next few weeks before pulling it off again.
Another interesting fault appeared in the form of a permanently lit driver's side indicator. After a bit of research on the forum it sounds like the alarm bitron unit is the culprit. Left indicator works fine but hazards don't, plus it comes on as soon as the battery is connected. Fingers crossed it will be a quick fix, the siren is no longer working so disconnecting the alarm isn't an issue.
I'm hoping to take it down to the D Rally at Little Horwood this weekend, so haven't got long to chase wiring faults. It could really do with an engine and gearbox oil change too, on time rather than mileage.
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post by Citjon » Sat Jun 14, 2025 10:05 am
Some interesting developments after a successful trip to the D Rally (and back).
Firstly I've found that turning the ignition key harder to the start position results in better starting, which indicates it is the switch at fault. Extra relay mod definitely required.
Secondly the battery light has now decided to stay on permanently so the alternator will be coming off. At least it didn't leave us stranded in Milton Keynes!
Onwards and upwards, possibly!
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post by Citjon » Sat Jun 14, 2025 6:37 pm
Alternator removal wasn't the easiest but it came out eventually. Required loosening of high pressure pipes and removal of the oil filter. Worst bit was squeezing it out between the pump and top radiator hose. Almost forgot to release pressure at the regulator, that would have been a bit messy...
Anyway once stripped down the slip ring has definitely seen better days. The brushes didn't look too bad considering it is probably the original unit.
The bearings feel OK, however, you can buy a rebuild kit with slip ring, brushes and new bearings for around £13.
Just to keep me on my toes the climate a/c panel has also gone awol. Could this be related? Had a quick poke around and found fuse F2 has been "professionally" upgraded to a separate 40A fuse.
Will see if it revives itself when the alternator is fixed.
89 CX25DTR T2
72 D Super 5 Black
Post by xantia_v6 » Sat Jun 14, 2025 7:04 pm
There is an "engine running relay" which takes its signal from the alternator and disables the A/C, heated seats and heated rear window, so probably related.
