wanted, rear suspension cylinder and gaiter
Southerneruk
Re: wanted, rear suspension cylinder and gaiter
Post by Southerneruk » Tue Jun 11, 2019 2:55 pm
Do you know the full measurments of all 3, I have this feeling that the ram might of pop out of the cylinder (well gone pass the rubber sills, because the piston when back in on its own)
I am wondering now if the one that was fitted was to small in length
Post by MTXM » Tue Jun 11, 2019 4:56 pm
I might be able to help with a s/h mk1 ram and gaiter if required. With regards, Matthew T.
Southerneruk
Post by Southerneruk » Tue Jun 11, 2019 6:00 pm
It will be handy to have Mathew, i might be able to do some thing with sealing the ram and if i can then a gaiter will be needed. let us know if you can and how much
Southerneruk
Post by Southerneruk » Fri Jun 14, 2019 9:54 am
Well I am still looking for those parts
Southerneruk
Post by Southerneruk » Fri Jun 14, 2019 10:52 am
Who can tell me about this number on a suspension gaiter S4 84368 4 what car would it fit
Post by White Exec » Fri Jun 14, 2019 1:02 pm
5484368 - Cit list this as mk1 Saloon rear gaiter.
Southerneruk
Post by Southerneruk » Fri Jun 14, 2019 2:46 pm
So no good for me then, what part nymber would i be looking for any idea
Post by White Exec » Fri Jun 14, 2019 4:26 pm
Cit list rear cylinder gaiter as 5461864, for Mk1 Estate.
Annoyingly, there is no part number listed for Mk2 Estate (just a diagram).
As yours is a "1.5", it could help if you could post the car's VIN number. Just possible that might help nail which cylinder/gaiter the car has.
Post by xmexclusive » Fri Jun 14, 2019 5:25 pm
As stated in my first post ALL estates use the same size rear cylinders.
So the part number 5461864 you have quoted above is the number for Mk 2 estates as well as Mk 1 ones.
Post by xantia_v6 » Fri Jun 14, 2019 7:20 pm
