Citroen Centenary celebration, Coombe Park
onza100
Re: Citroen Centenary celebration, Coombe Park
Post by onza100 » Tue May 21, 2019 12:58 pm
I Shall be there all weekend. Most likely in my Gs.
Look forward to meeting you all. Paul
Post by MTXM » Tue May 21, 2019 9:26 pm
Nooooo, bring a XM Paul and preferably the V6! It is the 30th Birthday after all! With regards, Matthew T.
onza100
Post by onza100 » Mon May 27, 2019 10:47 am
I need to take the engine out to fix the exhaust manifolds. I also have a leaking steering rack and an gearbox linkage that falls off regularly. Unfortunately that is the ball on the gearbox and not the linkage I've plenty of spares of.
Post by Dieselman » Mon May 27, 2019 11:11 am
For the gearbox linkage, just go underneath with a welder and weld the pressed in ball back into the arm. A permenent fix in two minutes.
Post by MTXM » Mon May 27, 2019 9:40 pm
I was sorry to hear about the issues with your V6 and I am guessing that is Andy's old car? I had the same gear change linkage problem with my 2.0i turbo and I managed to find a replacement ball with a screw and nut fitting. With regards, Matthew T.
onza100
Post by onza100 » Mon May 27, 2019 11:28 pm
That would be helpful Matthew. The edge of mine has worn flat so it's undersized.
Post by MTXM » Tue May 28, 2019 11:26 am
Unfortunately I cannot remember where I sourced the replacement part, which I think was from another part of a spare linkage! With regards, Matthew T.
Post by MTXM » Tue May 28, 2019 4:26 pm
Please also see my thread on the XM 30th birthday with initial details of the 'fringe event' this weekend and everyone please do come if you can! Regards, Matthew T.
ul9601
Orga / RP numbers: don't have any
Post by ul9601 » Tue May 28, 2019 9:48 pm
What about the French one at La Ferte Vidame in July - any one from here going?
'91 carb'd 2.0 manual
Post by MTXM » Tue May 28, 2019 10:16 pm
Yes, I will be there!! Regards, Matthew T.
