Yup was too good to be true, might take some of the other bits off his hands though!
As far as i can tell, the rest of the washer is undamaged, no idea why the cap has flown off but i did recently see someone else who was missing just the nearside washer cap.
Looking for immobiliser keypad cover/housing, nearside headlight washer cap.
- XmXD
- Orga / RP numbers: RP 6744
Re: Looking for immobiliser keypad cover/housing, nearside headlight washer cap.
1995, 2.5 TD, VSX, Manual, Hatchback, Silver, RP6744, N35 RDU
Member on here davetherave was making series 2 washer covers. He may either have some left or be prepared to part with his mould.
I doubt he will produce any more batches.
- XmXD
I'll try to get in contact with him, thanks for the heads up.
I'm now after a right hand side display/trip counter/clock as mine has LCD bleed
Have working keypad lid and washer cap here now.
There is a box of repaired/tested RH displays with trip somewhere either here or at the unit.
Those are the later centigrade ones.
Just found the NOS early type that reads in degrees F.
That still has the factory film over the display.
- XmXD
Ah bugger i literally just paid for a immob flap/housing last night! Bought from a member on here.
I'll take the headlight washer cap though!
Ideally would like to replace like for like, the original reads in degrees C and i have no idea how to read Fahrenheit! If you find the RH displays with deg C and trip counter, let me know and i'll take one of those too
Found the box of RH displays.
There are a few good working trip version in deg C.
Will put one display and the washer cap to one side.
