CITROEN XM ESTATE VSX 2.1TD AUTO Spares
XM-hooked
Orga / RP numbers: 6017
Re: CITROEN XM ESTATE VSX 2.1TD AUTO Spares
Post by XM-hooked »
Hi Gagamaxm,
I'm in the market for a R/H front sidelight and the turbo solenoid valve, which is usually mounted on the scuttle panel. I've sweat blood modifying a VW part but would be much happier with an original.
Thanks,
renault760 wrote:Now just where am I likely to find a nice, white, S1??
I don't have one, but we all know there is one, just across the Pennines from you. A few pounds spent with a carrier would have it with you.
Frankly, I'm amazed it is still available.
XM-hooked
Post by XM-hooked »
Hi,
Am I correct to be replying to Gigamaxm here or via a personal message? Thanks,
XM-hooked wrote:Hi,
If your message isn't for public consumption, take it to PM.
gigamaxm
Post by gigamaxm »
XM-hooked wrote:Hi,
Hi Chris I replied just earlier...
... I don’t suppose it needed to be private, but anyway will post what I find out about the state of the turbo (solenoid?) to public just so as not be mysterious lol!!!
XM-hooked
Post by XM-hooked »
Hi Gigamaxm,
Thanks, I am quite new to posting so am not sure of the correct form. My most urgent want is the R/H front sidelight which got shattered in a car park, followed by a Mk1 torsion spring (non electrical) seat belt pre-tensioner for the driver's seat, followed by the turbo solenoid valve, attached to the scuttle panel with one 2 wire electrical connector and behind it a "T" of 3 - 1/2" vacuum pipes. Let me know what you've got.
Thanks,
gigamaxm
Post by gigamaxm »
XM-hooked wrote:Hi Gigamaxm,
Thanks,
Hi,
Have had some delays getting car back up to aintree so havent been able to progress this at the moment to start
raynoon
Orga / RP numbers: 6043
Post by raynoon »
Aintree? Whereabouts in Aintree?
Post by MTXM »
That is dangerously close to you Ray I am guessing! Regards, Matthew T.
I think he's just throwing a stone over right now.
Right handed, it's pretty close...left handed, even closer.. ;)
