Hello
Re: Hello
Post by xantia_v6 » Mon Nov 13, 2017 8:46 am
Can you clarify whether the failure to proceed was immediately following the bang, or following the first subsequent stop?
Tallboy
XM newbie
Re: Hello
Post by Tallboy » Tue Nov 14, 2017 7:16 pm
The car went bang and then I realised I still had some drive although my speed was slowly decreasing.
I limped to the next sliproad where it stopped, I tried selecting any gear, but none left.
Re: Hello
Post by MTXM » Tue Nov 14, 2017 7:23 pm
I am still happy to help Tallboy if you can let me have your contact details. With regards, Matthew T.
Re: Hello
Post by xantia_v6 » Tue Nov 14, 2017 7:53 pm
Tallboy wrote:The car went bang and then I realised I still had some drive although my speed was slowly decreasing.
That sounds a bit like my E-type (see avatar) which went bang while accelerating off a slip road onto a motorway. It drove normally for about 5 miles on the motorway, then at the roundabout after exiting, the transmission was definitely slipping, but it kept going for another couple of miles before I got to an urban street where I had to slow down, and then it lost drive completely. In retrospect it kept working while the TC sprag clutch was freewheeling, but died as soon as the engine RPM dropped to the point where the torque converter (should have) started working.
The fault in that case was a sheared stator support shaft, which is the stationary shaft that takes the torque reaction from the TC stator.
Re: Hello
Post by Dieselman » Tue Nov 14, 2017 8:31 pm
What version of car is it? if it's a Series 1 it may be worth fixing, if a Series 2 then probably not.
If it's rusty to the point of needing a lot of welding, break it down quickly and dispose of the left overs.
What colour is it and what condition are the body panels in?
Tallboy
XM newbie
Re: Hello
Post by Tallboy » Wed Nov 15, 2017 5:06 pm
Thanks for your help everyone, I am going to visit the car tomorrow with MTXM, have a look over it and decide if I should proceed or not.
I have to say it is heartening how a group of people I have never met before can all be so helpful.
Re: Hello
Post by White Exec » Wed Nov 15, 2017 5:36 pm
It's something to do with Andre Citroen, and green blood in the veins . . . :roll:
Good luck with the inspection.
raynoon
Orga / RP numbers: 6043
Re: Hello
Post by raynoon » Thu Nov 16, 2017 3:50 am
You’re in safe hands with Matthew,
renault760
Re: Hello
Post by renault760 » Thu Nov 16, 2017 12:14 pm
Unless you happen to be made of glass! (Sorry Mathew, couldn't resist)
LG.
Tallboy
XM newbie
Re: Hello
Post by Tallboy » Thu Nov 16, 2017 3:30 pm
Ok...
Today Mathew came and picked me up and we visited the garage and had a play about with XM.
The rust issues are not enough to worry about for the time being, which is a relief.
Mathew drained the oil and the magnetic plate had a lot of filings on it, although there were no major lumps of metal in the oil itself, just particles.
Because of budgetary constraints and also the fact that the garage proprietor needs the car moved sooner rather than later I need it the car up and running fairly soon.
So my plan is to have a secondhand gearbox fitted and then as soon as I can, get the original gearbox fixed.
All I need is a gearbox...
Wanted 4hp18 gearbox.
If anyone can help I would be so grateful.
A big thanks to Mathew who didn't seem to mind scrapping about in gravel and mud and drizzle and who even took the battery off his own car to get mine started.
A true Gentleman.
