WANTED V6-24v parts required.
Re: WANTED V6-24v parts required.
No problem on the badges, they are the last thing on my shopping list.
Ill check stock levels if i have one for each side and find a third then no problem..
Paul, when rummaging through the stock if you come across the little air pipe that goes between the air box and the ICV valve could you let me know, also one of the clips that goes onto that pipe and up to the hydraulic suction pipe to hold it up, i have been unable to find them on the open market so far.
There was one on yog was there not dean? You mean the small diamiter pipe from the back of the air filter to the valve on the back of the inlet..??
Thats the one Paul, no it was missing from YOG and i never found one in the car either.
Wanted.
V6 ECU plastic box. Don't need the lid or relay cover.
Bloody hell will.. ive been to the farm tonight.. got your other stuff.. loads of ecu boxs but wont get one for you now..
No rush, just the rear location spigot broken off.
Like most.. but i think ive some unbroke ones but will need to check on that..
They all do it, you are better off fitting an M8 roofing bolt with lock nut on the back and cut to length.
