Selling off one (or bits
Post
by Dieselman » Sun Jun 18, 2017 8:25 am
citroenxm wrote:xmexclusive wrote:Depends on the age of the Mk 1.
Early Mk 1's got non standard cassettes with different size glass and roof hole position.
They will most likely go as a job lot to citroenxm with ray keeping his for providing the transport.
The mk.1 is an sed john with standard factory citroen roof unit same as all units fitted from 91 onwards. not the aftermarket type fitted to i and si models that also used a completely non standard roof lineing
I beleve the sed originally in 1989 was the only model to get the factory sunroof in the uk making them more compatable with roof linings and casettes.. ..
Agreed,
Having seen this car, I'm sure it has a standard XM sunroof, not the aftermarket type fitted in the UK.
I can only think of two with the aftermarket one, Neils "Goldie" and another, which escapes me at the moment.
Post
by Dieselman » Sun Jun 18, 2017 8:26 am
jamescarruthers wrote:Will a Mk. 2 casette fit a Mk. 1 car. Julian, who bought my old car, had a sunroof question. The cables have a few stripped points so it was odd in operation. I was going to drop him a line to say hello soon so could point this post out to him if it is possible to swap Mk. 2/1.
Is it the cables or the drive gear. When cables go the roof normally jams.
jamescarruthers
Post
by jamescarruthers » Sun Jun 18, 2017 9:05 am
Dieselman wrote:jamescarruthers wrote:Will a Mk. 2 casette fit a Mk. 1 car. Julian, who bought my old car, had a sunroof question. The cables have a few stripped points so it was odd in operation. I was going to drop him a line to say hello soon so could point this post out to him if it is possible to swap Mk. 2/1.
It did jam up, thankfully closed, and stripped the cog wheel. I opened it up and lubricated everything and put it back together. It ran nicely but slipped a bit and ended up with only fore/aft movement.
I'll point him in the direction of whoever ends up with the sunroofs-- if they want to pass them on
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Post
by citroenxm » Sun Jun 18, 2017 4:38 pm
Dieselman wrote:citroenxm wrote:xmexclusive wrote:Depends on the age of the Mk 1.
Agreed,
Any G reg model bar sed or sei should have the aftermarket fitted unit as sed or sei had them as standard in uk only base and i or base d or sd being without
Julianw
- Orga / RP numbers: 4937
Post
by Julianw » Sun Jun 18, 2017 11:28 pm
jamescarruthers wrote:Dieselman wrote:jamescarruthers wrote:Will a Mk. 2 casette fit a Mk. 1 car. Julian, who bought my old car, had a sunroof question. The cables have a few stripped points so it was odd in operation. I was going to drop him a line to say hello soon so could point this post out to him if it is possible to swap Mk. 2/1.
Hi all
I've had the gear assembly apart a couple of times - the gear wheel seems undamaged, though the wave washer had disintegrated, allowing too much free play and probably exacerbating the wear to the drive rack. I've replaced the washer so the gear is now in the correct position, but there are sections of the drive rack that are rusty and worn down, leading to it jumping teeth and getting out of sync with the cam/microswitch as soon as it is operated.
It looks like a factory fit unit, but then I don't know what the aftermarket units look like so could be wrong. Is there a specific thing I can look for that distinguishes the factory fit from the aftermarket units?
Thanks for mentioning it, James
Sent from my BV6000 using Tapatalk
Post
by citroenxm » Mon Jun 19, 2017 4:56 am
The unit IS factory unit as per later cars.. i know the car well.. like i said above.. all se models had them as standard..
Post
by xmexclusive » Mon Jun 19, 2017 7:54 am
Some of the surplus cassettes should get to Citroenxm in early July.
I will send as many as Ray can fit in and Citroenxm is willing to take.
I do not have the time to test or break and supply individual parts or units.
Post
by Dieselman » Mon Jun 19, 2017 11:37 am
As already said, it is a factory fit unit made by Webasto-Huliez.
Three easy methods of checking:
Aftermarket fit item is larger glass area, has mirror glass, an aluminium frame edge is visible on the roof top, the substructure is made of steel, the interior light is the smaller trapeziol type.
Factory fir is smaller glass area, has dot screen printed glass, no frame outside, plastic sub structure, larger double interior light.
Post
by MTXM » Mon Jun 19, 2017 12:52 pm
Not quite every 'G' reg. car Paul as my 12v auto has a factory sunroof! I also thought even early UK 'i' and 'd' spec cars had sunroofs and they were only omitted on late S2?
With regards,
Matthew T.
Post
by Dieselman » Mon Jun 19, 2017 1:08 pm
I think paul is saying that even though early low spec UK cars had sunroofs, they weren't factory fit, they were aftermarket, fitted at Slough. As you say, after a short while all UK cars had factory sunroofs.
