Hi Citroenmad
Are you still looking for C5 moulded mud flaps?
I saw a least one pair of originals still in Citroen packets the other day.
Can check type (front/rear/estate) and provide supplier contact details (Citroen Indy) if you are interested.
Would be the same arrangement as I finally organised for MTXM (for a set of real original).
You deal direct, no mark up.
Regard
Mudflaps Wanted - Please Help
citroenmad
Re: Mudflaps Wanted - Please Help
Hi John, no i eventually got a full set for the s1 C5, both from ebay brand new in boxes. Though one was a citroen dealer who did manage to find me a set of rears after i couldnt find any others.
Though im wanting some for a C5 facelift 2005 estate now, these are different mudflaps to the early S1 cars, i think citroen still supply these but ive found some on ebay, just need to check to see if they are the ones i need.
Thanks you for the offer though, if you find any front Xm flaps i might be interested
DerekW
Mudflaps may trap mud in unwanted places, but around here where tractors regularly lay a carpet of detritus on the roads (what ever happened to the rule that farners had to clean the roads if they fouled them?) they are indispensible
Derek
Derek
- terry g
ill check on monday, the fixings are a bit like a mini G clamp i think, probably be able to buy them at an accessory shop??
Does anyone know where to source some decent XM hatch ones, especially if at sensible money? For originality and to stop dirt being trapped I would prefer the S1 flat type. I believe my car had a full set but the fronts are missing, presumably after one got pulled off, looking at the arch. The rears are still on but one is cracked from the car sitting down for so long.
TIA.
TIA.
Hi Dieselman
Have a look atebay 180468689980.
I ended up sticking some universal flaps onto my SD. These are a bit pricey when you add in postage. Just go to your local motor factors, and expect tp pay in the region of £6 a pair.
savoy
Hello
i maybe able to help
bought a number of mudflaps from a citroen dealer a while back.
if you send me an e,mail to
malcolm.savoygarage@gmail.com
i will send a picture of the mudflaps by attachment.
CAN U HELP
i have a 1995 black xm 3ltr 12 xm and i could do with a good running engine.
Bought this running but has water problems ? been pulled in bitsbefore and need to
refit all parts and check what is wrong before removeing the heads if required.
A good engine would help out.
f you can help or know of a running lump please shout.
Regards Mlacolm
http://www.savoygarage.co.uk citroen specialist
CAN U HELP
Regards Mlacolm
Hello, another car from Devon, not seen them while they were down here.robert_e_smart wrote:Hi Matthew,
Are these the ones you are after?
Or these:
The top ones are the original Citroen XM ones, the second are a set of Citroen generics. I got the second set on e-bay, they do appear from time to time.
Which one? UFJ?
