Citroen Classic Challenge - 1st-11th June 2017!
Re: Citroen Classic Challenge - 1st-11th June 2017!
Post by xantia_v6 » Thu Jan 12, 2017 5:58 pm
Be sure to drop in and see us in Beaune on at least one leg of the trip.
Post by MTXM » Thu Jan 12, 2017 6:41 pm
That is very kind Mike and from the attached route plan you can see we are passing very close to Dijon and I gather you are some 40 minutes south-west! It would certainly be very nice to see you, either just us, or otherwise can your drive accommodate all twenty cars?! With regards, Matthew T.
Post by russ92xmsed » Thu Jan 12, 2017 7:09 pm
MTXM wrote:Thank you Russ and I am also sorry that you could not attend and especially after the experience of 2015! Hopefully the 2019 celebrations might be an option, including a return via the factory at Rennes! With regards, Matthew T.
Hopefully it will be. Would be nice. Should know more next month hopefully then I can get a good idea of what's in store.
Post by MTXM » Thu Jan 12, 2017 7:38 pm
That is a great cartoon Chris and many thanks for your kind wishes!
yep, plus phrase book but definitely no flex plates
Or replacement clutch in this case Steve!!
With regards,
Matthew T.
Post by xantia_v6 » Fri Jan 13, 2017 1:41 am
MTXM wrote:That is very kind Mike and from the attached route plan you can see we are passing very close to Dijon and I gather you are some 40 minutes south-west! It would certainly be very nice to see you, either just us, or otherwise can your drive accommodate all twenty cars?! With regards, Matthew T.
I rather suspect that the route that has been plotted for Friday 9th passes within 20 metres of our front door (it does't add much time if it wasn't). If you like we could do lunch at a little brasserie in town where my friend is the chef.
If you can spare another hour or two, then there are some other sights around town that you might find interesting. Any reasonable numbers can be accommodated.
David Hallworth
Post by David Hallworth » Wed Jan 18, 2017 1:07 am
I'm taking part in the trip this year as well :)
I won't be in an XM though, I've thought about taking my CX but I don't think I'm brave enough so I'm taking my V6 Activa for a good blast! Really looking forward to it now, it should be a great trip :)
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Post by MTXM » Wed Jan 18, 2017 1:25 pm
It will be good to see you then David and many thanks again to Mike for the invitation to call in! Regards, Matthew T.
paulstringer
Post by paulstringer » Fri Jan 20, 2017 8:03 pm
I'm taking the challenge this year with one of MTXM's previous stable so in good hands. Gotta say I'm feeling a lot more comfortable about going on the trip knowing Matthews going out there.
Citroen XM (S1) Prestige, 2.0i Turbo. Black. 1993.
Post by MTXM » Sat Jan 21, 2017 12:47 pm
It will also be great to have you in the XM team Paul and many thanks for the kind remarks!! With regards, Matthew T.
Post by xantia_v6 » Fri May 19, 2017 2:43 pm
On the Friday of the challenge (starting at Bourg-en-Bresse), you will be passing within 25 metres of our front door in Beaune, as it is on the most obvious routes to Savigny-les-Beaune.
You are welcome to drop in and say hello, or we could do lunch at a local bistro, before you head off the the Chateau at Savigny.
