parts needed help please
furriegurrie
Re: parts needed help please
Check to see if the rear windows aren't disabled in the centre console close to the armrest. There is a switch there to prevent children from operating the windows.
Window elevator repair procedure:
viewtopic.php?f=10&t=4293
and for some stainless steel cable:
viewtopic.php?f=10&t=7978&p=95165&hilit ... ble#p95165
EDIT, April 2018:
Current link to TecniCable: http://www.tecni-cable.co.uk/1.5mm-7x19 ... MBL-130kgs
Hope helpful.
EDIT, April 2018:
Hope helpful.
nosmokenopoke
Re:
[quote="Eddie nuff"]http://www.aepdirect.com/" onclick="window.open(this.href);return false; for the spheres.[/quote]
thanks dude
thanks dude
I have
2000 xm v6 auto exclusive 67k
2011 range rover sport autobiography
2008 mercedes sprinter lwb (bmw 330d engine fitted)
2002 renault clio van dci 255k drives mint
nosmokenopoke
[/b]
Yeah i will do them myself as i am a garage owner. I have already changed the fluid but will do it again once i fit new spheres. I am going to replace them all. I didn't give much for the car and i think she deserves a full set
Thanks for info
Jon
raynoon wrote:You can't go wrong with AEP Direct for spheres, there is a 'how to' guide on here if you're changing them yourself. Don't forget to replace the LHM if the car has been sat for 5 years.
Thanks for info
Jon
I have
nosmokenopoke
xmexclusive wrote:With non working windows work out if the problem is mechanical or electrical first.
Look for dropped glass, wedges or tape holding the glass up as this shows drive wires broken.
You can get repair kits from ebay (will add details later) but the quickest fix is a secondhand winder.
I have a few recovered ones and can supply details of the fitting.
For the electrical side all but the drivers window are driven by simple 2 wire motors.
All these three windows have a chain two switch control so that both driver and passenger can operate them.
The rears also have a child isolation switch.
The switch contacts oxidise over time and are a more common problem than the motor wires.
Cleaning and regular use quite often fixes them
Problems with these are best checked by testing electrically at the switch nearest the suspect window.
With the switch removed the plug can be checked for voltage.
If volts and earth are present check with a spare known good switch.
The drivers window motor is a bit more complex on your XM so will come back to that.
Great info John. I am going to take door cards off and check everything this weekend. I am sure it will be something simple as its never carried any passengers due to it coming from a home with no kids and they owned it from new. Not only that the seats look like brand new.
The drivers window motor works but i can her the cables in the door crunching up. As for the others there is no sign of nothing.
Like you said i will start with the simple things likes switches ect and ill test the wires.
Thanks for the info John. Its a great help for a new xm owner
Many thanks Jon
I have
nosmokenopoke
Dieselman wrote:e-crofting used to sell window wire kits, but a pedal cycle cable would work just as well.
Chevronics have some bumper trims in stock, but not cheap.
Your car sounds like a real bargain.
Cheers dieselman..
I will take a look this weekend and see what i need.
As for the car, yes bargain. I am over the moon with it. I was looking for a old bx diesel and then found the xm dumped on a drive. TBH i am a diesel man unless its 500bhp with 2 turbos and 4mpg
thanks for info
Jon
I have
nosmokenopoke
russ92xmsed wrote:Hi Jon,
Welcome to the forum, noticed your in Gloucestershire, where abouts?
Sounds like you have picked up a bargin.
Hi Russ, I am only in Quedgeley. Yes, i was smiling driving it home even though it was a hard ride
Jon
I have
nosmokenopoke
furriegurrie wrote:Check to see if the rear windows aren't disabled in the centre console close to the armrest. There is a switch there to prevent children from operating the windows.
Ive tried that buddy. Ill have it apart this weekend
Thanks for help
Jon
I have
nosmokenopoke
White Exec wrote:Window elevator repair procedure:
Hope helpful.
Thank you Chris. your a Diamond
Jon
I have
If you feel the need to change it, let me know. I like diesels, but a late V6 Exclusive is of particular interest to me.nosmokenopoke wrote: Cheers dieselman..
As for the car, yes bargain. I am over the moon with it. I was looking for a old bx diesel and then found the xm dumped on a drive. TBH i am a diesel man unless its 500bhp with 2 turbos and 4mpgI would love this car to be diesel but i am still happy as fook
thanks for info
Jon
