Everyday XM?
Re: Everyday XM?
275k is an achievement alright, not hyper mileage but damn good going all the same.
Re: Everyday XM?
It's my own fault for using biodiesel
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
If you can't find the leak clean the pump then coat with talcum powder or flour and run it. The leak will soon be obvious.jonathan_dyane wrote:I guess the old girl does deserve another chance although the cursory glance little time permitted earlier didn't reveal where the leak was emanating from only that it seems to be dripping from the underside of the pump so likely not the drive shaft seal which is good...
Exploded image of the pump. Thre aren't many seals (O rings), one on the rear, one on the front, nose seal, metering head seal, maximum fueling screw seal. A seal kit will contain them all.
http://www.westportparts.com/dieselvw/i ... csPump.JPG" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
It possibly is the Bio-diesel that has ruined the seals.
Re: Everyday XM?
That's a great diagram, thanks. Believe it or not I have a seal kit in stock somewhere. Can you remove the metering head insitu or does the pump have to be on the bench? Thats the seal I'm worried it might be.
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
The bio may have helped it on its way but i wouldnt say it would never have leaked if you had stuck to dino juice.
Re: Everyday XM?
The metering head can be unbolted from the outside with the pump in situe if you create enough clearance.
You might as well heve a look yourself as if you end up with not being able to complete the job, a diesel specialist can put it back together for you. Just mark a witness on the pump support bracket before removal and align it back to that when reinstalling.
Re: Everyday XM?
I broke it!
Unfortunately there wasn't enough length on the bolts to release the metering head enough to replace the seal and when I removed them the head came away and all of the workings dropped out
I'm going to see Paul tomorrow for another pump; I really didn't fancy trying to put it all back together...
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
I'm still struggling unfortunately.
I tried fitting an injector pump off a 1.9td Xantia which I though would get me on the road but for whatever reason it didn't run properly with it. I got my pump on the bench and managed to reassemble it however unfortunately something has gone seriously awry in that it revs it's balls off when you start it up.
At this juncture I need another injector pump or someone else to take the car on. I'm not sure at the moment which I would rather! Please do PM me if you have a pump that might be suitable or any interest in taking the car off my hands.
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
The revving sounds like teh govenor isn't connected.
Re: Everyday XM?
This might help.
http://www.ebay.co.uk/itm/CITROEN-XM-2- ... SwaNBUkBxY" onclick="window.open(this.href);return false;
