Breaking 2.1td Silver Exclusive series 2
- onza100
Re: Breaking 2.1td Silver Exclusive series 2
cool thank you
I would quite like to keep the wings myself and I am sure Dave and I between us could bring other parts to the X Rally in April! Regards, Matthew T.
Dave still has the rear subframe and other associated parts including the wheel plates Neil, all impressively restored, plus a very nice set set of professionally repainted 24v wheels! Regards, Matthew T.
- onza100
I should be at the x rally so that would be excellent.
Unless the car is a Sinker the subframe should not be much different. When anti sink was added around 1996 a bracket on the nearside was added for the anti sink sphere.. I cant remeber if it was bolted or welded on though. .
I believe I supplied the subframe that was sent for powder coating.
It was recovered from a "M" reg Mk2 2.1 auto and did not have anti-sink.
Anti-sink brackets are bolted.
davetherave
Have messaged a few people Re: bits, will get round to the rest tomorrow!
Here are some pics of some more bits available, trying to clear out all diesel specific bits as if I get another Xm I feel it will be of the V6 variety.
Cylinder head + Injectors (Bosch KCA 17S42)
Had the head skimmed and pressure tested and the injectors refurbished.
Brake calliper rebuilt and coated about a year or so ago.
Alternator rebuilt and new bearing a few years ago.
Turbo + Manifold- Think I had intended to send off for refurb
2.1td engine + Turbo from a Xantia I believe- timing belt removed and condition unknown
Head Gasket set for 2.1td Multi layer steel one- think I have head bolts also
Near side 1/2 calliper new
Dave
Dave
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
davetherave
Still plenty of bits left if anyone needs anything-
The engine is still available- I have a hoist that can be used to remove.
Anyone interested in this before it goes on ebay? I had it done with the Alloys.
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
