for sale Jaap's Turbo Diesel ...
Re: for sale Jaap's Turbo Diesel ...
Post by russ92xmsed » Sat Jun 04, 2016 10:10 am
Excellent news!! Turby had great ride quality. Hope you enjoy them both. Good to hear someone has taken these two on. :D
Riverhead
Post by Riverhead » Sat Jun 04, 2016 3:46 pm
Thanks Y'all.
Yes it drives lovely. Much better drive than I expected from the auto box.
When the bushes go in it will make it much better.
Tends to wander.
He did so much work if had to be worth keeping. Engine seems very sweet.
Not a bit of smoke.
I'll keep ye informed.
H
Riverhead
Post by Riverhead » Thu Jun 09, 2016 7:19 am
Well it failed as expected on all the wishbone bushes.
Nothing else was picked up on I was delighted to say.
Has anyone changed these bushes before?
Should I go with main dealer parts or spurious?
Any tips on getting the bushes pressed?
Thanks
Huw
Riverhead
Post by Riverhead » Thu Jun 09, 2016 7:21 am
It does tend to sink in the back every time I brake.
The accumulator is clicking every 5 seconds so I reckon that's the issue.
I've one from a Xantia. 1.9td.
Are they similar?
Post by xmexclusive » Thu Jun 09, 2016 8:19 am
There are currently NOS wishbones on ebay for about £75 each.
New bushes will cost around half this and then need fitting.
Be aware that rear bush failures on these arms are often not the rubber.
The bush support base is alloy and has been known to break up.
These items are no longer available so scrap cars are the only source.
Post by Dieselman » Thu Jun 09, 2016 8:38 am
Fitting isn't too bad a job.
Cut the old ones off with an angle grinder slit through then drive them off. Drive the new ones on with a tubular drift against the central steel.
Riverhead
Post by Riverhead » Thu Jun 09, 2016 11:23 am
Hi John
Do you have a listing number for the wishbone? I see the Peugeot 406 but not the XM.
Thanks
Any opinion on the accumulator sphere from a Xantia?
Riverhead
Post by Riverhead » Thu Jun 09, 2016 11:51 am
Hi John
Thanks
Found it😉
Post by xmexclusive » Thu Jun 09, 2016 12:28 pm
Acc sphere should be the same.
Riverhead
Post by Riverhead » Thu Jun 09, 2016 9:21 pm
Hi john
They only have one.
I'm going to go with new rubbers.
I had both sides off in an hour. Was surprised how nicely they came out.
I'll try the sphere
Thanks again
