R/H driveshaft, new, £20
Re: R/H driveshaft, new, £20
I thought I would check now but my shafts are 29 spline outer and 37 spline into the diff and are larger solid shafts, I have fitted the even larger hollow shaft as a replacement in the past but this is neither.
I will leave it as this must be for the manual BE3? Box cars which have smaller shafts than the auto box cars do.
If there are no takers I will have it for the boots and outer CV as the hub splines are the same on this so it won't go to waste completely but if there is someone out therewith a 2.0i manual or early 2.1td manual it will be more use to them.
Thanks
