Headlamp Washers in Action
Re: Headlamp Washers in Action
A video from where Paul, YouTube?
You tube or photobucket.. I put a small video and in the ceo project topic of the interior lights.. but it opens externally instead of playing in the post..
Not sure about photo bucket as I don't use it but if you use your mod powers to enter my post under the edit function you can see what part of the video I'd you need to copy in.
Ciaran
Site Admin
Orga / RP numbers: 1234
5678
91011
Post by Ciaran »
The YouTube embed function only works if you put in the 10 character video ID from the YouTube URL, after v=, between opening and closing YouTube tags.
Think I explained it better here.
If you're having trouble with it just let me know.
As Dean says, if you edit his post you'll see the video ID placed between the two YouTube tags, like this:
Code: Select all
[YouTube]XXXXXXXXXX[/YouTube]
I really must get round to rewriting it so its smart enough to parse the entire URL, saves people having to manually isolate the 10 characters.
Depends on your device too Ciarán, when I had a real puter YouTube gives the tag for embedding in the vid description so is easy to grab, now I have a tablet and only have access to YouTube via the app they don't actually give you the id tag on its own, I have to pull it out of the full link.
kenhall
Post by kenhall »
citsncycles wrote:I think that's cool too, but need the relay to make mine work - are they a common item or is it another search for hens teeth?
If you have the original red/pink coloured relay i would try re-soldering the internal connections. The solder joints can crack (as mine did) which stops the relay operating. Relay is located somewhere below the steering column IIRC.
Ken
eifion
Post by eifion »
Ah, that's how YouTube links are supposed to work. I always wondered.
[youtube]UPBwSycGmPM[/youtube]
1995 XM 2.5TD (now dead and gone)
1998 XM 2.1TD Auto Estate
2000 XM 3.0V6
1972 D Special
citsncycles
Orga / RP numbers: RP 5709 - Turbo SD
Post by citsncycles »
Ken
I have the relay, but when I removed it it was full of water! I'll have another look at it as it may be salveagable (and I'll be amazed if I spelt that last word correctly!)
Mike Sims
Mk1 XM Turbo SD
dollywobbler
Post by dollywobbler »
I can't get excited about headlamp washers, and I'm not just saying that because my SX is too povo to have them.
Headlamp wipers on the other hand...
[youtube]yMHnQgeda4c[/youtube]
1986 2CV6 Dolly, 1980 Dyane
I notice from your youtube channel you seem to have a thing for headlamp wipers, very 80's!
To be honest i dont see the point in washers only, spraying water at something doesnt clean it after all, those Saab wipers are brilliant though, they look like they would actually work. I can remember as a child marveling at headlamp wipers on my dads Volvo estate.
