New XM owner with a few questions
Re: New XM owner with a few questions
Being a Y3 s1 xm there is no common central obd connector.. Each ecu has its own two pin plug that you connect a diagnostic to .. You then read each ecus faults directly and not globally..
Post by xantia_v6 »
Tsuku wrote:A few more issues have arisen:
7. The 2.0 turbo engine is slightly twitchy when driving at constant speed and throttle. On wide open throttle it's even worse, really choppy acceleration. It also lights up the Check Engine Light for a short while after giving it some beans. I started by replacing the spark plugs and ignition leads, but they didn't help. What's next? Have also bought a new ignition coil, but have yet to fit it.
Change the fuel filter if you have not already done so. A blocked filter can cause low fuel rail pressure that gets worse as more power is demanded.
Tsuku
Orga / RP numbers: 6303
Post by Tsuku »
xantia_v6 wrote: Change the fuel filter if you have not already done so. A blocked filter can cause low fuel rail pressure that gets worse as more power is demanded.
Good point, thanks. I just ordered a new fuel filter.
