Wanted: Alloy wheel bolts
Re: Wanted: Alloy wheel bolts
Okay Will I shall bring all the bits to LH! Regards, Matthew T.
Bump.
I still need 4 alloy wheel bolts and a nsf door window seal.
Will...
Which window part exactley??
The rubber seal at the window bottom that clips onto the door skin and makes a rain seal.
I have the bolts with me Will but sadly could not locate a good seal. Hopefully Paul can help. Regards. Matthew T.
OK, Thanks.
Bump.
N/S/F window to glass seal wanted.
Can peeps please have a look as the X Rally is approaching.
I will have a sort through a big pile of door seals and trims that I have Will!! With regards, Matthew T.
Bump.
NSF door to bottom of glass seal still wanted.
I have just recently organized my spares Will and I shall check tomorrow! I wondered which day(s) you plan to attend the National? With regards, Matthew T.
