WANTED - Citroen XM mk2 fusebox/ignition switch
- onza100
Re: WANTED - Citroen XM mk2 fusebox/ignition switch
I have a spares car that should have what you need.
We do also have a ready removed board too...
station
It's not the fuse box, it's the ignition switch. Took it out and the contact was frazzled inside the switch.
Things flew everywhere and I'm not bothering trying to put it back together again.
Tried a Xantia ignition switch which fits the barrel and connectors, but is also broken on the 'start engine/starter' position.
