Mark's XM.
Re: Mark's XM.
Post by Dieselman » Sun Jan 04, 2015 7:43 pm
As luck would have it, I've just done a tutorial on this today.
Dieselman wrote:To make your posts more interesting you may want to add pictures.
The best way to do this is to host your pictures on an external site, then in the body of your post use the Image
The Code for the above picture is shown below to show how this works.
Code: Select all
[IMG]http://i126.photobucket.com/albums/p110/dieselman_bucket/Car/The%20Manor/2nd%20September%202014/IMGP0920_zps1e0f9756.jpg[/IMG]
I don't think you can see the forum this is on without registering, but feel free to click the linky. It's a new forum today. ;)
http://www.mercedesworld.net/forum/view ... ?f=22&t=16" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
mds141
Orga / RP numbers: 8542
Re: Mark's XM.
Post by mds141 » Tue Jan 06, 2015 5:26 pm
Had a quick investigation into the water ingress today. The seal for the roof rack mounting holes is still firmly sealed against the roof, so can't be getting in there, but the secondary drain channel, which is a strip of U shaped plastic has become crushed over time, so tried to reshape it. I also adjusted the striker so the door sits tighter against the body. Time will tell.
Mark Smith.
1997 Honda Firestorm.
dollywobbler
Re: Mark's XM.
Post by dollywobbler » Tue Jan 06, 2015 5:47 pm
Where is the water appearing inside the car? On mine, I can slide back the roof and clearly see where water has come between glass and seal. My second attempt at bodgery - lots of sealant - doesn't seem to have been entirely successful so I've slapped some more on!
1986 2CV6 Dolly, 1980 Dyane
mds141
Re: Mark's XM.
Post by mds141 » Tue Jan 06, 2015 6:08 pm
Front and rear passenger footwells, although the majority of water is in the front. Sunroof doesn't show any signs of failure and the headlining is dry. The carpet immediately underneath the plastic trim of the door sill is also wet, which leads me to suspect the plastic U shaped channel isn't doing it's job of draining water to the bottom of the A pillar. Adjustment of the striker plate has resulted in the door closing tighter against the body and door seal. Heavy rain forecast for the next few days, let's see if it's worked.
Mark Smith.
Re: Mark's XM.
Post by citroenxm » Tue Jan 06, 2015 7:14 pm
Is your Drain away channel ALL clear under the scuttle trim????
If its blocked up, water level builds and it then floods in past the Air intake right next to it..
Theres a water drain off tray that covers the blower intake for upper catchment, but not for a "Lake" next to it..
Look in past the cut out for the headlight washer filler bottom of the windscreen with bonnet open!
mds141
Re: Mark's XM.
Post by mds141 » Tue Jan 06, 2015 8:09 pm
Cheers for that. I take it the scuttle panel needs to be removed to have a look? End caps removed and then what? I've never removed the scuttle panel.
Mark Smith.
Re: Mark's XM.
Post by russ92xmsed » Tue Jan 06, 2015 9:13 pm
Should be easy Mark, screws in each end of the scuttle once caps removed. Two each side ....at least on the mk1. Then open bonnet, should be a central screw. Then lift out .. Backwards...Watch for the 4 prongs if it has it. It's a fiddle but carefully does it.
mds141
Re: Mark's XM.
Post by mds141 » Tue Jan 06, 2015 9:21 pm
Cheers Russ. I'll have a go. What's the guess the scuttle end caps will break. :-(
Mark Smith.
Re: Mark's XM.
Post by Dean » Tue Jan 06, 2015 9:56 pm
Hair drier them for a long time to ensure they are warm to the core first, prising old plastic in the cold will only end in tears.
mds141
Re: Mark's XM.
Post by mds141 » Tue Jan 06, 2015 10:17 pm
In the absence of a hair dryer, I might have to wait until June. :-)
Mark Smith.
