Post
by MTXM » Wed Nov 05, 2014 4:22 pm
Many thanks for your kind remarks chaps and I am pleased to have given the car a new lease of life!!
so im not a regular then mathew.. I didnt get a gearbox run down saga at cosford...
I do remember mentioning it to you at Cosford Paul but I know it was all rather frantic!!
With regards, Matthew T.
Post
by russ92xmsed » Wed Nov 05, 2014 8:18 pm
Eddie nuff wrote:
Neither am I . . . but I did get a full explanation of the baking of the cake.
good bit of cake that!
Post
by MTXM » Fri Jul 08, 2016 9:40 am
Some of you may recall the earlier saga with a third removal of the engine and gearbox due to a cracked crankshaft-torque convertor flex plate, when the opportunity was also taken to rebuild and install a spare engine! I am now pleased to report that the car is now back on the road again after my recent completion of the work and a MOT pass. There have been a few small issues, with leaks from the radiator that required replacement and an abs valve block hydrualic return hose to re-tighten, and then a couple of days ago the petrol pump mysteriously died. In general I am very pleased with the car since the engine is much quieter and smoother than before and the box is also performing well after two rebuilds!! Here are a couple of recent photos and I look forward to showing the car at the National this weekend! With regards, Matthew T.
Post
by Dean » Fri Jul 08, 2016 9:59 am
Well done Sir, lovely looking car that one, here's to many miles of trouble free motoring from here on in!!!
Post
by MTXM » Fri Jul 08, 2016 10:32 am
Many thanks Dean and hopefully that will be the case! With regards, Matthew T.
Post
by Dieselman » Fri Jul 08, 2016 12:01 pm
Looks like MTXM towers have gone up another notch...
Well done on persisting with that car Matthew. Iirc, there is a flex plate on ebay (or somewhere) at present, for about £28.
Post
by MTXM » Fri Jul 08, 2016 12:22 pm
Sadly the properties featured are not ours Will but thank you for your kind remarks! I do have another spare s/h flexplate but if you could send me a link for the item spotted I would be grateful. With regards, Matthew T.
Post
by russ92xmsed » Fri Jul 08, 2016 12:36 pm
Well done Matthew, looks great. Hope she behaves now. Looking forward to seeing it this weekend...not met this one yet!
Post
by MTXM » Fri Jul 08, 2016 3:08 pm
Much appreciated Russ and she has been to a few rallies before, including the last CXM, but admittedly not in a while! I look forward to catching up further. With regards, Matthew T.
Post
by citroenxm » Fri Jul 08, 2016 7:40 pm
Very Nice, one of my more prefered colours.. Tell us if you know Mathew, what was the MOD the specialist did to prevent sticky valves again??
