First ever Citroen
HooXM
Re: First ever Citroen
Post by HooXM »
Thanks for the tip Russ
George
Xena - 1995 XM 2.0 Turbo Exclusive - Magenta
djg
Orga / RP numbers: 7903
Post by djg »
Isn't the sensor a bog standard NTC temp sensor, available anywhere for a song?
Bye,
Gábor
Post by Vince »
Welcome to the forum and Citroen ownership :?: :)
Guys, whats the part number for the temp sensor? I need one :P
HooXM
Post by HooXM »
Thanks Vince
George
Post by xantia_v6 »
Vince wrote:Welcome to the forum and Citroen ownership :?: :)
96044396 until RP 4982 then 6445F9, Lots of Chinese clones of the latter floating around, don't know about interchange with the former.
Early cars had the sensor screwed to the front bumper inlet grill.
The early sensor version listed above was electrically the same it just had a thicker base to the encapsulation.
Later version then became standard for all uses.
Clones are fine and should be around £10 on ebay.
HooXM
Post by HooXM »
Dipped beam now fixed thanks to the technical pages! One cleaned up relay behind the headlamp :-))
George
HooXM
Post by HooXM »
Spent most of the day scrubbing the interior - it was filthy! Pleased with the results though!
George
dollywobbler
Post by dollywobbler »
Ok, all that wood and leather is making my SX seem very plain indeed! Looks great.
1986 2CV6 Dolly, 1980 Dyane
HooXM
Post by HooXM »
Thanks very much. I need to sort out my interior mat issue - have one citroen carpet mat in the drivers footwell, one rubber citroen one in the passenger footwell and aftermarket ones in the back. Does anyone have any odd mats knocking about?
George
