All XM- most refined?
Re: All XM- most refined?
Post by russ92xmsed » Mon Aug 11, 2014 12:36 pm
I have noticed this too Ciaran, if you have a hole or a patched up door foam sound deadening stuff, it transmits far more noise. I think Dean found a good supplier of this foam for his XM rebuild. I think he also added extra sound deadening around the car too. So that would be very interesting to see if it is quieter at speed.
Another car I was surprised by in terms of road comfort was an Ami 6. Very soft indeed, infact something softer than a DS. Not quiet though..... :lol:
kingp
Post by kingp » Mon Aug 11, 2014 1:12 pm
In the Xantia at least i know the ES9 is quite good at 140(!) and at anything upto 110 there isnt much engine noise that comes into the cabin so the XM would be even better as it has less wind noise due to reduced drag :)
djg
Orga / RP numbers: 7903
Post by djg » Mon Aug 11, 2014 2:29 pm
Ciaran, the one I'm contemplating is STP Hood Solution but I don't know if something on the bonnet only would do wonders or not. Certainly less than a full solution but still, how much?
Bye,
Gábor
Post by Peter.N. » Mon Aug 11, 2014 3:00 pm
I didn't find mine noisy Ciaran, I would say its at least as quite as the C5 - but then I rarely drive above 60mph :)
Post by Dieselman » Mon Aug 11, 2014 6:51 pm
Try using rustproofing wax on the inside of the panels, it makes a surprising difference.
Post by Charles M » Mon Aug 11, 2014 7:31 pm
Fitting dynamat or similar does make a huge difference to noise levels, doors and front bulkhead and floor. I've done it to a W124 Merc and to my Allard (that was fun). Oddly, at motorway speeds I think the 2.1 manual diesel is pretty refined.
kingp
Post by kingp » Mon Aug 11, 2014 7:44 pm
Or just get that bitumen roof felt for flat roofs :) asda aome weight mind but does the same lol
