CCC National Rally 18-20th July 2014
Re: CCC National Rally 18-20th July 2014
You can buy ABS reluctor rings seperately.
Jim, if your interested, I have a Certain C5 wanting an annoying tyre pressure sensor message deleting...
....if poss!
I shall be there Friday to Sunday in the XM and accompanying C5.... With XM25 Mugs.
mds141
- Orga / RP numbers: 8542
Thanks Dieselman. Are all the reluctor rings the same?
Mark Smith.
1997 Honda Firestorm.
No, but they are in sizes.
The internal shape of the ring can also vary to suit the shaft joint outer casing.
There are some on ebay for £1.40 each posted but these have a taper over half the inside.
mds141
I'll drop it off at the garage when the MoT is due. Unless a Lexia session can sort it.
Mark Smith.
Plan to pop in on Sunday as it's fairly localish for me.
You'll all wholeheartedly disapprove of what I'll turn up in so I'll probably park outside, but ah well...
Oh, and here's a rally poster:
It really doesn't matter Franklin. It will be good to see you. What you travel in is quite irrelevant..
Just for the crack I did consider coming along in my new 'Citroen'
A real shame guys but i wont be able to make this one
I really planned on attending this year but ive got that much work on at the moment next sunday will be my first full day off so i have promised Linda and the kids that we will spend the day together.....They wont go for a car show though
I will be down at the september show though...hopefully in the xm too
That's a shame Vince but at least you can make the September one...
