Wvo users.. advice please
Re: Wvo users.. advice please
Im NOT dooing a 100% WVO, there will always be diesel in there too! Ive no time to fart around adding heaters etc.. Just the basics so it will help reduce fuel costs.
kingp
10-20% dino should do the trick then
I'm looking at one of the fphe type ones that will run just before the filter and lag the filter when the temps next drop below 5' I think. Saves an absolute fortune this veg stuff
ONLY that I have a small low volume free supply is why this has happened!!
kingp
Can send you some svo over with your other bits if you want some Paul, 75p/l and dropping a little each day
Theres no point neither car is on the road and it will be some time now before they are with this new job so theres no use for it.. and no I aint putting it in the hdi and no theres no time what so ever to make it bio..
thanks for the kind off anyway will.. very kind.
kingp
No worries fella
I get it every month or less so just let us know
We will get that stuff over to you at some point
endorfin
Morrison's had an offer of 4 litre tins of veg oil at £1.62 per tin which is very cheap, a smidge over 40p per litre for new oil.
If you're going to put a Xantia type thermostat/filter heated housing on, there is a simple mod that keeps it on all the time rather than the small stat closing off the coolant when it gets to operating temp. All you need is a 10 cent piece. It doesn't do any harm to leave it hot all the time when running on diesel either:
http://www.biopowered.co.uk/wiki/Filter ... nd_Citroen
Good luck with the new job, Paul.
Nigel, Ive got an XM Proper sort of thermostat housing, that, well obviously, does NOT contain a thermostat as its on the back of the 2.1 engine...endorfin wrote:Morrison's had an offer of 4 litre tins of veg oil at £1.62 per tin which is very cheap, a smidge over 40p per litre for new oil.
Cheers Will! VERY long hours, leaving me NO CAR TIME what so ever, and that is NOT an understatement unfortunally...Dieselman wrote:Good luck with the new job, Paul.
