Wanted: hydraulic pipes
markysimon
Re: Wanted: hydraulic tubes
Post by markysimon »
citroenxm wrote:Where are you Mark??
Hi there – I'm in Powys, mid-Wales. Nearest town of any size is Llandrindod Wells. Nearest Citroen specialist is in Hereford, but after messing up my last service, I don't trust them. :cry:
Cheers – Mark
1997 V6 24valve Exclusive
1995 XM VSX Turbo (Deceased)
We were in Powys last weekend, We stopped in Barmouth for the night then went across to Welshpool to Powys Castle!
Anyway, Llandrindod Wells, past through many time, or past near, going to South Wales.
I do NOT stock the NuCi pipe BUT I DO have the Fare Tool for 3.5mm and 4.5mm pipes and the Flares too..
markysimon
citroenxm wrote:We were in Powys last weekend, We stopped in Barmouth for the night then went across to Welshpool to Powys Castle!
Aha-ha – small world isn't it? :) useful to know about the plumbing, but how d'you feel about 'unbending' and possibly welding sills? :(
Cheers – Mark
Mark,
Have a look at my Blogs on here!!
Before:
viewtopic.php?f=19&t=4366&start=180
After:
viewtopic.php?f=19&t=4366&start=210
Of course fully sealed with under seal after completed..
markysimon
Hi again,
What's your postcode and d'you think the welding/bending could be done in a day, or would I need to leave the car with you? :roll:
Mark
djg
Orga / RP numbers: 7903
Re: Wanted: hydraulic pipes
Post by djg »
Does this cupronickel gizmo apply to the pipes I'm looking for as well? Could they be replaced with those? If so, why not?
Bye,
Gábor
I have bought small stocks of 3.5mm, 4.5mm & 6.35mm CuNi tube to use on my cars.
As well as being more rust resistant CuNi tube is a bit more ductile so bends and flares easier than steel tube.
If made up pipes are ordered from Pleiades (01487 831239 - pleiades@tesco.net) then they will supply CuNi on request.
Flare nuts supplied for 3.5mm pipe are usually large flat 10mm ones not the small flat Citroen 8mm ones.
That cuts down the risk of the nuts getting rounded with use.
I am sure Pleiades will be happy to quote for making up your pipes.
My pipe supplies came from Malcolm Lockwood (01274 640590 - http://www.mlockwood.org.uk).
To work with the pipe you need a flaring tool with dies to suit Citroen pipe sizes and flare shapes plus stock of the flare nuts.
Good quality flaring tools cost between £70 and £400 depending on the sizes and types of flares to be made.
They are also hard to find supplied with the Citroen dies.
Getting someone to make up a few pipes to order is the cheapest way unless you are repiping complete cars.
djg
Post by djg »
Thanks, I'm heading there to check out the possibilities.
Ooops, no website but a Facebook page. Then I'll write...
Bye,
Gábor
djg
Post by djg »
No, producing my own pipes isn't the solution I'm after, I'll be perfectly happy with them made to order...
Bye,
Gábor
