Gold 2.0Si
Re: Gold 2.0Si
Post by russ92xmsed » Tue Feb 26, 2013 7:59 pm
Glovebox catch might be tricky..... ;)
Re: Gold 2.0Si
Post by citroenxm » Tue Feb 26, 2013 8:00 pm
We all need Glove Box Catch's for S1 cars Eddie..
I could help with the wheel trims however, I HATE them, I think I may have four spare.
Gear Knob same as S1 Xantia's and simply pull upwards with a GOOD pull...
Hatch Cover? Do you mean parcel shelf?? Ive got one, with massive great big 6x9 speakers in it...
turbo_imp
Re: Gold 2.0Si
Post by turbo_imp » Tue Feb 26, 2013 8:04 pm
Sounds like you are making a good list of things with order of importance :)
What are you going to stort out first?
Eddie nuff
Re: Gold 2.0Si
Post by Eddie nuff » Tue Feb 26, 2013 8:29 pm
Hatch cover/Parcel shelf :| but with speakers in?? urgh.
Preciesley... Not what Id do either!!!!
Eddie nuff
Re: Gold 2.0Si
Post by Eddie nuff » Tue Feb 26, 2013 8:32 pm
turbo_imp wrote:What are you going to stort out first?
Idle speed first, then Oil switch, then flush radiator. By that time the TFR should be here and I'll be able to steam clean the engine bay.
Re: Gold 2.0Si
Post by Dieselman » Tue Feb 26, 2013 10:41 pm
iirc, these engines use an idle bypass, so it's probably just jammed.
I might have a load cover, but the hinge part may be worn out (they tend to do that). I probably have some wheel-trims spare too, but am less keen than Paul to part with them.
Finding some Romana velour is going to be like looking for a needle in a haystack.
Yours isn't a base spec car, it's a S level.
vive la difference
Re: Gold 2.0Si
Post by vive la difference » Wed Feb 27, 2013 8:50 am
Hi Eddie
A warm welcome from Oxfordshire, I am sure you will have lots of help and encouragement from everybody on the forum, They really are a great source of information
Regards Brian
Ps I have 8 no wheel trims available, e.mail if anyone is interested
citroen xm S1 v6
Range Rover P38 4.6 HSE
Alfa Romeo 147
Re: Gold 2.0Si
Post by CitroJim » Wed Feb 27, 2013 5:10 pm
citroenxm wrote: I have decided, shes is worth dooing up....also a 2.1 TD manual base model
Definitely Paul :D
It's good to see real base model being loved and appreciated. they can be a great joy and a lovely change from all the top-spec models...
I don't think I've ever seen a proper base model. Looking forward to seeing it ;)
Re: Gold 2.0Si
Post by robert_e_smart » Wed Feb 27, 2013 5:27 pm
I would love a nice base spec normally aspirated D12 XM, with a brown dash for added class!
Re: Gold 2.0Si
Post by russ92xmsed » Wed Feb 27, 2013 5:47 pm
Oh yes. I've seen one on the net. Never knew they existed! Soooo spartan...amazing they even bothered.
