1998 XM - 2.1td - Steamy Windows!
turbo_imp
Re: 1998 XM - 2.1 VSX Manual
Thanks guys, under arch (up skirt
) pictures tomorrow morning, I think there is a little seperation from looking, not bad but probably worth further investigation.
Have you really got a Turbo Charged Hillman Imp? Or is it just a car you'd always imagined but never got built???
I took a look. Great to see it. More sill work!
That ..as you keep saying Paul, needs to be back on the road.
A friend from my uni days had an imp...a racing imp that is.
Sill work is Done on her Russ...
Its the damm rear chassis AGAIN just identical to my 24v Manual V6... Rear subframe off and make some corners and welding!!
I don't know,.... is it your storage practices causing this lot!
I thought you had got those sills sorted. Excellent. I expect to see it come CXM
turbo_imp
Yep, was turbocharged with a VNT15, then supercharged
All built without a garage, just a little work shop, some ingenuity, and a lot of patience!
To Be Honest Russ me TOO!!russ92xmsed wrote:I don't know,.... is it your storage practices causing this lot!![]()
I thought you had got those sills sorted. Excellent. I expect to see it come CXM![]()
This new SD 2.1 to X rally, then sell it with any luck and sort the SED and get her down there..
Thats the years plan anyway...
F N Hell, and the Imp engine could take all that! Well I wouldnt mess with that at traffic lights!turbo_imp wrote:Yep, was turbocharged with a VNT15, then superchargedAll built without a garage, just a little work shop, some ingenuity, and a lot of patience!
Hats off to you! Impressive! Still Live or has she died??
All that air going into a coventy climax engine.
Note the engine suspension being cantral.
The strut tops look pretty good to me.
