Xac hit the OFF Button again on FCF???
Rommel
Re: Xac hit the OFF Button again on FCF???
Post by Rommel » Mon Feb 25, 2013 8:26 am
CitroJim wrote: Mine decided to lock me out of the tailgate this afternoon, only to release itself about 10 minutes later all on its own :roll: .
I have suffered from this odd quirk too Jim. Though mostly when I first got the car, it hadn't been used for a while before then. In recent months it hasn't happened. Was the V6 similarly unused before you got it? Perhaps the mechanism gets lazy or stuck through lack of use.
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
Post by citroenxm » Mon Feb 25, 2013 10:13 am
CitroJim wrote:
Dieselman wrote:
CitroJim wrote:
Went to look at a brake judder problem on another XM V6 today. Found the disc warped after just 1500 miles and worst thing is they're not exactly common or cheap for the V6... Then the airbag light came on for no good reason...
Are they definitely warped. Disks virtually never warp, but suffer from friction material deposition or not being flush with the hub.
Dial gauge says they are Will..
I've had warped discs on a Xantia in the past and again they failed when they were comparatively new..
I HAVE back this up aswell... Ive had xantia disks warp WITH NO sticking calipers either to blame, the car started shuddering under breaking... result? Swap the disks, and yes, smooth as you can get.. So I agree about disks warping...
Post by CitroJim » Mon Feb 25, 2013 6:22 pm
Rommel wrote:Was the V6 similarly unused before you got it? Perhaps the mechanism gets lazy or stuck through lack of use.
I reckon so Rohan.. I found the (for want of a better word) handle you operate to open the tailgate was getting stuck in the up position and not returning to the normal flat position of its own accord..
A bit of working and WD-40 sprayed into the mechanism seems to have done the trick now...
Post by Dieselman » Mon Feb 25, 2013 6:49 pm
Brake disk warping myth.
http://www.stoptech.com/technical-suppo ... ther-myths
I have personally had brakes with severe grabbing, just like a warped one would. A good scrub with a wet-stone and normal service was resumed.
Post by citroenxm » Mon Feb 25, 2013 9:30 pm
BACK ON TOPIC!
Anyone else not getting onto FCF AGAIN!!???? :cry:
Post by citroenxm » Mon Feb 25, 2013 9:40 pm
Its OK - I got onto FCF just after I posted the upper message, so ignore me..
Carry on talking warped discs!!.. :lol: :lol: :lol: :lol:
Post by russ92xmsed » Mon Feb 25, 2013 10:11 pm
Ok...well warped discs are discs that are warped. 8-)
:twisted: :lol: :lol: :lol:
Post by citroenxm » Mon Feb 25, 2013 10:14 pm
And they do warp.. ive got some more on my xantia.. hell of a wobble and judder under braking and its not ball joint or track rod as she passed her mot recently ..ill do them soon in fact the rears are on the metal...
Post by russ92xmsed » Mon Feb 25, 2013 10:18 pm
Have you read that article Paul, it flatly refuses warped discs exist! Curious....
Post by CitroJim » Tue Feb 26, 2013 5:39 am
The FCF did go down last evening. Not sure when or when it came back up again...
I'm not saying anything more on the subject of warped discs until I see what happens when the suspect one in question is replaced ;)
