WTD - 2.1TD clutch cable
Re: WTD - 2.1TD clutch cable
Post by citroenxm » Sun Jan 13, 2013 4:32 pm
Dieselman wrote:
citroenxm wrote:
Ive got a cable that sometime in the past has broke at the Pedal, on the end of the short cable... Strange.. Still got it too...
That is an easy fix, just bend a piece of metal with a cut out for the cable.
really will?? so what is the pedal gonna grip on too!!! there's nothing on the end of the cable it has snapped off....????
Post by Dieselman » Sun Jan 13, 2013 9:09 pm
Your failure is different to normal, so you need a nipple crimped on to the cable. You should be able to find someone to do that. Look for local cable and rope suppliers.
Post by citroenxm » Sun Jan 13, 2013 10:45 pm
Up here will.. :D :D :D :D :D :D :D
Post by Dieselman » Tue Jan 15, 2013 9:28 pm
A local boatyard or chandlers will either be able to do it or have a contact.
