Hi Dean,cit tool 4129-T translates into manufactures p/n OUT204129T,is still available but i can't find a price.
robertm
ebay - sphere removal tool??
robertmnorton
Re: ebay - sphere removal tool??
I think I will stick to my home made motorbike chain strap wrench.
boyse7en
Considering that when I changed mine last year I had to beat one for hours with a cold chisel and a 2kg lump hammer before it eventually came loose, I don't think this tool will be up to a really tight sphere. I was getting worried that the chisel was going to actually pierce right through the metal as it 'peeled' a 4mm thick, 30mm long slice out of the thick central band on the sphere.
If I ever get rich enough to replace all the spheres every 2 years, this should do the job fine.
1999 Alfa Romeo 166 V6
1977 Triumph Stag 3.0 V8
1984 Tiger Cat E1 2.1
1977 Austin Mini 1380cc
2000 Ducati Monster M600
2006 BMW F800S
2006 BMW F800S
Had you depressurised the system and hit the sphere around it's neck with the hammer. This normally makes them loose enough to undo by hand.
boyse7en
I'd done everything. Pressurised the system, depressurised the system, hit it with hammer, made a 30" long strap wrench thing (which bent when i put a 4ft length of wood on the handle for extra leverage). Repeated everything repeatedly, until eventually, with my arm feeling like it would fall off, it finally gave way and undid.
From memory, a couple of the spheres were dated 199x, so had presumably been on there more than 10 years. Hopefully, the ones I put on won't be quite do hard to get off.
2006 BMW F800S
2006 BMW F800S
The rears and centre ones on mine were original, I think and they were tight, but I found it was the fluid pressure that was holding them so well.
Obviously the rears need pressure to stop the rams turning, but the centre on came off easily once the pressure was released.
To get the accumulator off, which is the one everyone says is difficult, was childs play. Just ensure there is no pressure at all, then a few taps and unscrew by hand.
