Off topic chat about anything you like. Doesn't have to be about XMs (though they will inevitibly come up!). You can even discuss
non-Citroens
in here!
Post
by citroenxm » Thu Jul 29, 2010 2:11 pm
Yes, in this post:
Removing and some work done
Theres some of it there, as for full pictures,
There IS a body dent on that Rear panel above the rear wheel... Its not split the paint at all either.
Minus the alloys, she now has steels with S2 Trims, however, I DO have a set of original Flat Trims that could go on...
And the Strut Tops
Regdorpten
Post
by Regdorpten » Thu Jul 29, 2010 2:52 pm
Did you ever get the air con sorted Paul? And what are the orginal flat wheel trims you're referring to?
1994 S2 CT auto hatch green Exclusive, SE London.
Post
by citroenxm » Thu Jul 29, 2010 7:34 pm
No I didn't, I never managed to get hold of a Series 2 System. The Air Con compressor is still fitted, as is the Evaporator in the dash... so it just needs the dryer, condenser and assosiated pipe work from an S2 car - I say S2 to be sureits an R134a system..
Im reffering to the "Bowling Ball" trims, fitted to base spec S1 cars!! Someone, got a pic???
Post
by Dieselman » Thu Jul 29, 2010 8:34 pm
These ones.
http://www.club-xm.co.uk/forum/viewtopi ... =19&t=1244
Post
by citroenxm » Thu Jul 29, 2010 8:44 pm
Thankyou DM Yes those awfull ones!
Post
by Dieselman » Thu Jul 29, 2010 9:09 pm
citroenxm wrote:Thankyou DM Yes those awfull ones!
I knew you'd say that...That's why I showed a picture of Roberts car instead of mine..
Post
by robert_e_smart » Thu Jul 29, 2010 10:09 pm
Thanks Will!
Post
by Dieselman » Thu Jul 29, 2010 11:09 pm
robert_e_smart wrote:Thanks Will!
Actually that was a joke Robert....I only used your photo because your trims are in much better condition than mine.
Here's mine for reference.
http://www.club-xm.co.uk/forum/viewtopi ... =19&t=1609
Post
by XMX » Fri Jul 30, 2010 12:26 am
citroenxm wrote:.....................
I'm referring to the "Bowling Ball" trims, fitted to base spec S1 cars!! Someone, got a pic???
There's always
THIS thread folk's can use for when referring to wheel trims or Alloy wheel's (If you can remember) !
Post
by citroenxm » Fri Jul 30, 2010 6:52 am
Should that not be made a Sticky????? Thats rather a usefull posting!!
