I don't think anyone has a CAD drawing of the bell-crank.
A local precision engineers could mill a stainless steel bell-crank for you, or a fabricator could make a U shaped sleeve you could then cut and drill to fit over your existing plastic piece.
You could even make a metal piece using only hand tools and a drill.
Either way, I would be inclined to keep a needle roller bearing, as it should stop the bell-crank, or pivot pin, wearing.
Greetings from Cyprus! XM 2.0 manual, 1992, RHD. VF7Y3AC0...
Re: Greetings from Cyprus! XM 2.0 manual, 1992, RHD. VF7Y3AC0...
SergeL
Finally I have managed to get back to the forum for last several crazy weeks due to high work load, relatives health issues etc.
Thank you for compliments
"Your car looks in really good condition, anyone from UK will be very envious as there is no rust at all and it even appears to have all four jacking points...and no sunroof...Oh là là..."
Yes, jacking points are still in place but some bended a little bit by not qualified or diligent technicians for many years. But panel beating work in this case is easier than fighting rust. Actually there was some surface (hopefully) rust in the area of clutch cable going into its line to pedal but it should be inspected better (under noise insulation)
Yes, there is no sunroof. The less sunroofs - the less issues ))
"Your images open up to full screen and are large files due to being taken in portrait, as opposed to Landscape, giving more ground and sky, rather than actual car."
I tried to download better quality images but the website did not allow me due to high resolution. I will try to arrange maximum acceptable resolution next time with less sky
"I'm not sure whether your car is Meteor grey, (EYY), or Mercury grey (ETW). The paint code should be printed under the cables on the inner wing behind the left headlamp, in front of the air filter housing."
Thank you for this guidence. Will check tomorrow.
"If you paint the window upright glazing bars in satin black, you will have the original "band of glass" look."
Thank you for sharing the idea. It appears upright glazing bars color is still original (in acceptable condition for daily use
. As I come to painting at some point I will ensure they are satin black.
"The forum paint and trim codes charts have been another victim of regional censorship, but you may be able to see them in this, linked to, thread.
If possible can you please save them and we can organise a method of re-hosting them on the forum server. From storage, I have rebuilt the images in my previously linked to post, but these ones were created by another party and we have no local storage of them.
viewtopic.php?f=6&t=7553 "
Great and impressive work done by you. Thank you! I have saved all the pictures under this link successfully. Very interesting and informative schemes
"Was the interior fabric originally in velour and has been changed for leather? Black leather seats normally came with black carpet and headlining.
Also does the car have a dot matrix display each side of the steering wheel, electric seats and rotary automatic cabin temperature and fan speed control? I can see the second rear window so this would make the car similar in spec to the UK "S" level trim. (mid range)
I assume it has A/c, so might have the push-button climate control."
The interior was grey (I will ask the previous owner whether it was leather or fabric). The previous owner changed it to black leather about 10 years ago. Carpet is still grey
May be I will find black carpet somewhere (I think it should be from RHD car). New headlining is black. Yes, the cars has a dot matrix display each side of the steering wheel (the one on the right side should be replaced or fixed - I will try to check why it does not work). Yes, electric seats and rotary automatic cabin temperature (not working. reason to be checked) and fan speed control (working). Yes, there is second rear window - probably UK "S" level trim. Effectively it was the car designed for UK market as the speedometer is in miles as well. The A/C appears to be a push-button climate control (to be filled with gas as the previous owner temporarily disconnected A/C line but did not fill A/C subsequently )
"Your car appears to be riding a little high at the front, which is common for Xm that have been laid up but the height selection control left at normal ride height.
Over time, the spring rod deforms and makes the height corrector setting incorrect. I always set mine to low before switching off, if leaving for an extended period of time."
Yes, you are right as to a little high front. Thank you for your advice. I followed it as well.
"The height should be:
Front; 144 +10 / -7mm from the ground to the flat of the subframe.
Rear; 431 +10 / -7mm from the ground to the rear chassis rail just behind the rear subframe mount.
Measure with the engine running and after manually lifting and holding the body up until it sinks down, then allow it to raise itself to height.
The adjustment is by loosening the clamp on the anti-roll bar and operating the height corrector, then tighten the clamp."
Wow! You know everything about this car! Amazing ) I appreciate this specific instruction as well. It will be interesting exercise for me soon
"It's worth reviewing the Citroen training material to understand the Xm hydraulics systems.
viewtopic.php?f=13&t=10291"
Thanks. I learned a little bit about the suspension features, issues and solutions. I hope to manage it by myself with you valuable support.
"Apologies, you are probably going to be a bit overloaded with technical information initially, but will end up with a perfect running Xm. Just let us know how you are getting on and what we can do to help.
Using only basic hand tools, there is nothing you cannot fix yourself on a Citroen Xm."
I appreciate your attention and time to my story and car. It is very interesting experience with all respects for me. Including meeting great people on my way to restoring this extremely interesting car for me. I enjoy all this technical information you generously provided.
BTW as you happen to be in Cyprus let me know and I would be happy to arrange some excursion for you in old city of Nicosia if you find time.
Not done by me, but by another forum member Russ. If you have downloaded the images I will contact you via pm and ask you to send me the images, so we can rebuild them back into the thread as attachments. Some while ago the forum had issues with attachments so members were using external hosting, which has now become problematic.SergeL wrote: Fri Jun 19, 2026 6:37 pm
I think the whole forum are now booking flights to Nicosia...SergeL wrote: Fri Jun 19, 2026 6:37 pm
SergeL
I have sent the pics via WETRANSFER. Pasted a link to PM as well (if it is more convenient)
"the whole forum are now booking flights to Nicosia..."
)) BTW there is ferry launched several years ago from Greece to Cyprus. That is it is possible to travel with vehicle to Cyprus in summer time now. Some travelers like such new logistic. Quite affordable fees (subsidized by government)
SergeL
Thank you for advices one more time. I will talk to a fabricator to make U shape cover. It could be the easiest option in my case
Ensure it is no larger than the original plastic bell-crank, otherwise it won't fit into the housing.SergeL wrote: Tue Jun 23, 2026 3:47 pm Thank you for advices one more time. I will talk to a fabricator to make U shape cover. It could be the easiest option in my case
SergeL
Clutch cable BELL CRANK manufactured from aluminium (original bearing retained)
Let me share good news - new clutch cable bell crank was manufactured (from aluminium). The clutch cable set was assembled, cleaned, greased and installed. To say short, interesting experience and new skills
. With such skills I feel now I am ready to start new business - Citroen / Peugeot garage
Upon installation of the restored cable the clutch pedal proved to be quite easy. I am wondering whether there are any pivot points to grease other clutch elements to ensure it’s correct operation.
The next scheduled action is to inspect brakes - within last test drive uneven brake force was identified on front wheels at least… I hope to find brake service thread here
I approached the air conditioner specialised service to fill out the air conditioner system. As we did it the air conditioner compressor shaft seal blew out upon short test drive. Thus I will dismantle the compressor so that the seal to be replaced by the this specialist.
I found that I can’t change ventilation system airflow with rotary airflow regulator. Hope to find respective thread here how to fix it
I drove my wife first time. She liked comfort of suspension
Thank you very much for your strong support!
It's good to hear the clutch cable is fixed and light in operation.
The only pivots are the bushings the actual release fork rotates on, which is an item to be lubricated when the gearbox is away from the engine.
It's interesting that the A/c specialist can replace just the seal, normally we have to buy a complete compressor.
It's possible one of the front brakes has seized, but more likely the disks are rusty from lack of use and will clean up during operation. If seized, remove the wheel and brake caliper and with the park brake released wind the piston back into the barrel using clockwise turning, clean and grease the slide pins and it will probably be fixed.
The inner pad has a pip that locates in the piston cut-out to stop it rotating, which ensures the parking brake self adjuster functions.
For the heater airflow, do you mean the direction control knob is stiff due to, the the flap beings seized, if so, you are in for a bundle of fun. see thread viewtopic.php?f=6&t=6292
Having said that, as you are now a Citroen mechanic, you should be able to do this quickly, in your sleep.
If you do have to unbolt the pedal box, go under the car and unbolt the park brake pedal support from the base of the firewall and keep the parking brake mechanism attached to it, which will be a lot quicker and easier than removing and refitting the parking brake in situ.
As an aside, I have now seen a clutch bell crank hand fabricated from three 6mm steel plates ingeniously screwed together.
I would think ideally it could do with being welded together, for absolute rigidity.
SergeL
Thank you very much for new insights re Servicing brakes, manual brake and air flow regulator mechanism. Such clear and practical guidance is much appreciated as it would more difficult to find all those concentrated knowledge by myself.
Apologies for later reply. I was travelling last weeks with limited access to computer. Visiting my parents in Germany. Waiting for returning home to fix all those issues.
As to AC it is quite hot issue in our climate as we have to use it at least from March to November
